Thanks for sharing. I could not for the life of me get the harnesses off. Watching the video helped and finally got the trail light installed.
Quick question, how hard or easy was it to fish the wire from the trail sight down in to the wheel well to meet the rest of the harness? I assume the wire length is good?Peeling back the wheel liner required some REAL effort and even then I was just barely able to feel out the factory connector for the headlights.
But once I did that, everything worked perfect and the plug-n-play adapter was made with some real quality. I think this is one of Mabett's better releases, I appreciate the visibility this adds to my Bronco from the side.
It’s easy. I just did it. Just use a thin fish wire taped to the fish wire and it’s only a minute to do.Quick question, how hard or easy was it to fish the wire from the trail sight down in to the wheel well to meet the rest of the harness? I assume the wire length is good?
Thanks, is it pretty obvious what path to follow down from up top?It’s easy. I just did it. Just use a thin fish wire taped to the fish wire and it’s only a minute to do.
Either way will work. I pulled it up from the bottom.Thanks, is it pretty obvious what path to follow down from up top?
Because I was barely able to peel back the wheel liner enough to fit one of my hands inside, I was forced to run the wire from the trail sight towards the outside of the car further away than I would have liked. I didn't have the visibility or proper angle on it to fish it out of a spot that was closer to the harness interface.Quick question, how hard or easy was it to fish the wire from the trail sight down in to the wheel well to meet the rest of the harness? I assume the wire length is good?
Thanks, I wonder why the wheel well liner was such a task on your vehicle. Were you not able to get the nut out of the top of the liner that is near the upper part of the fender? Did you see this video example below? It was for the installation of a different product, but did a very good job of showing how to get the liner off and reach the light harness right around the 8:30 mark.Because I was barely able to peel back the wheel liner enough to fit one of my hands inside, I was forced to run the wire from the trail sight towards the outside of the car further away than I would have liked. I didn't have the visibility or proper angle on it to fish it out of a spot that was closer to the harness interface.
It still reached the harness that plugs into the OEM headlight connector just fine but there's very little slack left on the wire which I'm not crazy about. Nevertheless, physically connecting it wasn't too big of an issue and everything worked properly the very first time I reconnected the battery and fired it up.
This might be a stupid question and I apologize, but in addition to the add a fuse, you also have the actual provided wiring harness plugged in to the headlight harness which is then plugged in to the headlights correct, you're not just running the add a fuse from the trail sight lights to your fuse panel?I need some help and advise. I suck at electrical. I have the trail lights installed and am trying to power them with the fuse box. I want them on all the time. I followed the wiring from the kit and have one fused plug to install. But no matter where I put the fused plug I’m getting no power. I’m trying to use location 124 but the fuse doesn’t feel like it’s going in deep enough to make contact. Plus why doesn’t this setup require a ground. Thanks
Per above not sure if you saw @Wildfire1 's post. He was having an issue with a loose wire in the add a fuse harness. Maybe that is what is going on?This might be a stupid question and I apologize, but in addition to the add a fuse, you also have the actual provided wiring harness plugged in to the headlight harness which is then plugged in to the headlights correct, you're not just running the add a fuse from the trail sight lights to your fuse panel?
Yes I’m only trying to run from add a fuse. The instructions state that as an option for being on all the time.This might be a stupid question and I apologize, but in addition to the add a fuse, you also have the actual provided wiring harness plugged in to the headlight harness which is then plugged in to the headlights correct, you're not just running the add a fuse from the trail sight lights to your fuse panel?
I installed the lights fine today and am having no luck powering them with only the fused connection. I ran the wiring like the instructions said and plugged them into spot 124 in the fuse box and nothing lights up with engine start. I’m not sure but shouldn’t the fused connection have a ground when not using the headlight module ? So another thought is it possible to direct wire them to one of my aux switches ? Thoughts ?Not really “issues, per se”, but it was kind of tight as I pulled the wheel liner back as little as possible and just did it by feel.
interested in details when you get them all wired up. I didn’t have time to try and figure it out today.
Thanks I’ll check that as well. So the question is has anyone wired them with add a fuse only and not through the headlight module ? If so what did you do.Per above not sure if you saw @Wildfire1 's post. He was having an issue with a loose wire in the add a fuse harness. Maybe that is what is going on?
You still need the wiring harness to the lights in addition to the add a fuse. Look at step 12 again on page 4 of the instructions.Yes I’m only trying to run from add a fuse. The instructions state that as an option for being on all the time.
