Got ‘em installed today. Just connected directly to the headlights for now. Might change it up, cuz I’d like them to be on with the DRLs.
Thanks for the update. They look great. I’ll try the fused connection so they are on all the time. I’ll let you know how that works out. Did you have any issues connecting or reaching the headlight harness ?Got ‘em installed today. Just connected directly to the headlights for now. Might change it up, cuz I’d like them to be on with the DRLs.
Not really “issues, per se”, but it was kind of tight as I pulled the wheel liner back as little as possible and just did it by feel.Thanks for the update. They look great. I’ll try the fused connection so they are on all the time. I’ll let you know how that works out. Did you have any issues connecting or reaching the headlight harness ?
Looks good. When you say, on with DRLs. Do the blinkers work even if just DRLs are on? It doesn't look like your headlight is on in the video, but just to confirm.Got ‘em installed today. Just connected directly to the headlights for now. Might change it up, cuz I’d like them to be on with the DRLs.
As currently set up, they are not on when the DRLs are on, and do not function as blinkers.Looks good. When you say, on with DRLs. Do the blinkers work even if just DRLs are on? It doesn't look like your headlight is on in the video, but just to confirm.
Oh ok, it was hard to tell, thank for clarifying. Oof, that's definitely a shortcoming with the provided harness.As currently set up, they are not on when the DRLs are on, and do not function as blinkers.
when the headlights are on, they do. (Hard to see, but headlights are on in the video)
To be clear, I did only use the headlight adapters, and not the additional wiring to the fuse boxOh ok, it was hard to tell, thank for clarifying. Oof, that's definitely a shortcoming with the provided harness.
Do the blinkers work even if the headlights are off? Obviously the factory ones do, but would like to know for these trailsight lights.As currently set up, they are not on when the DRLs are on, and do not function as blinkers.
Not the way I have them connected currently.Do the blinkers work even if the headlights are off? Obviously the factory ones do, but would like to know for these trailsight lights.
Apparently I’m an idiot. I cannot seem to find the head light harness on the passenger side, and the driver side seems super tight to get to. Is there something I’m missing? Can anyone post a short video of how to access the headlight through the wheel well that shows the full process?
