Timsvtgen1
Tim
PA
2014 Tremor, 2018 Focus ST
Leaving this here-
https://www.tfltruck.com/2020/04/le...-the-next-ford-ranger-or-bronco-based-pickup/
Leaked: 2022 Ford Maverick Truck? Could This Be the Next Ford Ranger or Bronco-Based Pickup?
April 30, 2020
What can this be? A 2022 Ford Maverick pickup truck? Here is an exclusive look at a 3-d model of a tailgate with large MAVERICK stamped into it. TFLtruck received this model from an anonymous source with insider knowledge.
Ford Maverick
The source says the the dimensions of this tailgate match a truck like the current midsize Ford Ranger. The source calls this future truck a “baby version of the Ford Raptor”.
2022 Ford Maverick
If the dimensions of this tailgate are on the smaller size, it rules out the new 2021 F-150. The Maverick could be a special off-road trim for the Ford Ranger, but it could also be a whole new pickup truck that is based on the Ford Bronco or the Bronco Sport platforms. It can also be a version of what is rumored to be the next Ford Courier mini-truck.
In any case, this tailgate image shows a large oval logo in the center with a cutout for what is likely to be a rear-view camera. Also the top of the tailgate shows several cuts and creases that may be hiding a tailgate step or an extra folding section.
Advertisement
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis, 2017 Honda Civic, 2019.5 Chevy Silverado
Blackcat
South Carolina
From what I've read, it sounds like more of a delivery/work truck than anything. Not sure how excited I'd get about it. Think Transit Connect pick up truck.
FirstOnRaceDay
Devin
Toledo Ohio
dealers at the meeting stated it looked like a proper truck. And as small as the old school ranger (second gen)
And should still have a 1500lb payload and 3000lb towing. More than enough for a little truck. Similar to that ranger as well.
Escape_Artist
Nick
Houston, Texas
2019 Ford Mustang GT;
A transit connect based front wheel drive tiny little “truck” the size of a Focus? Drive a connect for any length of time, feel how absolutely commercial work truck focused it is, see how plasticy and basic it is, then come back and tell me if you’d want to drive one with the back cut off if you weren’t a delivery guy for a local auto parts store, don’t run a pest control company, or aren’t part of the data division of a local telecom. Payload will be minimal, trailer towing around 1500 lbs if you’re lucky and if you’re wider than an anorexic model you’ll feel cramped on a long drive.
This is what Chrispy had to say about the Courier. Now remains to be seen if the Maverick is a version of the Courier or something different entirely
MaverickMan
96 bronco sport 91 comanche eliminator 93 v8 zj 80 amc eagle 85 cj7 laredo 79 ford quadravan(inoperable due to tragic fire)
Alot of people still use work trucks and honestly everything out there now is either too fancy to work out of or has too high of bed rails to get into. My comanche is 4wd and lifted 3 inches and at 6 ft tall with a belly andi can reach over the bed rail put both palms flat on the bed. Cant do that in any ranger or f150 or colorado or taco. Maybe the nissan but thats not far from a redesign. For the self employed handymen, landscapers, parts runners, for surfers, dirtbikers, and a whole lot of other small jobs people, not to mention global market workers. They all need a truck that can haul, get good mileage, and be easy to work out of all day, especially if it starts at 20,000 and tops out under 30,000. The only small trucks now are vans and nobody wants to load 20 fertilizer bags in their van.
MaverickMan
I used to(5 years ago) have 92 ranger with a 4.0 manual regular cab shortbed 8.8 rear. Sure i had to get in a certain way being 6ft 300lbs but i did it every day without complaint. Got 22mpg highway, and could smoke the tires in every gear except overdrive. I even did a 1800 mile roadtrip in it with a buddy one winter to go to the ocean for a day one winter. Wasnt bad at all. It was perfect for my 23 min daily drive. And when i needed to pick up a engine block or clear brush from my sisters house it fit everything i needed. The 91 comanche i got it about 5% bigger than it was and i drive it 4 days a week hauling coconuts and compost. On trash day i can squeeze 9 brute trash cans in the bed to haul to the road. 6 ft bed 2000lb payload on a dana 44 axle. If you put a good axle under a small truck people can get real work done and not break the bank or the gas pump.
Escape_Artist
Nick
Houston, Texas
Yes agreed if they put good componets under it and it has a good payload capacity it will be great. What Chrispy said about minimal payload and maybe 1500 lbs towing does not fit the small work truck you are describing/wanting.
MaverickMan
Well lets hope that if its fwd based that it has a beam axle in the rear. Nobody(smart) tows anything bigger that a small single axle trailer with those small trucks. Jet ski, mower, atv type stuff. Keep the total weight under 4000 and payload 1200 on the base and 1800 or 2000 on a hd model. Plus that render has it as a slightly extended cab which should take care of comfort issues. We can olny hope that ford remembers the things they are good at. Putting that 8.8 in my ranger was genius, that is the same axle as a 90s econoline 7000lb van in a 3300lb truck.
FirstOnRaceDay
Devin
Toledo Ohio
I have a hard time believing the towing will only be 1500lbs. The transit is the old platform.
The new Escape has a towing cap of 3000lbs. It should be at least that. If not more. payload will be 1500
BroncoJeremie
Jeremie
Cedar city
2006 Ford F-150
Vehicle Showcase
Something smells fishy don't know what but something is off on this whole thing
ChrispyKC
Kansas City
2018 Expedition Platinum, 2016 Escape SE, 2015 Jeep Wrangler 2DR Sahara
I’m thinking they’ll call Courier, Maverick but I don’t know if that’ll be the USDM name or not. There’s also another van coming, but I think that’s not til ‘24 or ‘26. Metris sized.
ChrispyKC
Kansas City
It’s unibody and TC only tows 1500 or so.
ChrispyKC
Kansas City
Escape has more room and more structural attachment points for the receiver hitch.
