Damn, that looks good, well done. I have a velocity Blue Badlands on order. I,m going to have to copy you on this. White never crossed my mind until today.
I would not have recognized those wheels as stock BB. What a change. I think the project looks great. The beauty of the bronco, make it unique, make it yours.I wanted to get a Retro Look, and Line-X wanted $750.00 to do the top and hatches. I had read a lot about Raptor Liner (I have no connection with the Company) and decided to give it a try. I used my Kubota RTV to try out the spraying of the liner and had real good luck with it. So I gave the top a shot at it.
Once the top was off I washed it twice with car wash, and then did a third wash with Dawn Dish Soap. When it was dry, I went over all of the surface with 220 grit sand paper, and then wiped it down twice using Lacquer thinner. After that was dry, I went over everything with a tack cloth to remove any dust or small particles that I missed.
I then used Adhesion Promoter over all of the surface and let sit for 20 minutes, and during that time I mixed up the Raptor liner. If you do this project, keep in mind that the Blue Painters Tape and Green Frog Tape do not stick well to the seals. I had a little overspray where the tape did not stick.
My final part of the Retro Build was having the Factory Big Bend wheels powder coated white. The Tires are BFG-K02's size 285-75-17. No rubbing during turns and the Crash Bars are still in.
Nothing special about my equipment. I have a 30 gallon Dewalt compressor, and used the Adjustable sprayer that Upol sells. The adjustable sprayer gives you the option to have a heavy or fine finish. BJ.
That’s the tape we use for painting airplanes. Definitely the gold standard.Looks amazing!!! I may do this to my 11/14 build when it arrives.
FWIW, for anyone doing this, the 3M Green automotive 233+ tape will stick better than any other masking tape to hard to bond surfaces. It's the gold standard for masking tape in the body shop/collision world. Places like Napa auto parts have it as do any store that sells automotive paint.
It comes in widths from 1/8” to 4”.
Looks Great! Given all that work I think I would have gladly paid the 750!I wanted to get a Retro Look, and Line-X wanted $750.00 to do the top and hatches. I had read a lot about Raptor Liner (I have no connection with the Company) and decided to give it a try. I used my Kubota RTV to try out the spraying of the liner and had real good luck with it. So I gave the top a shot at it.
Beautiful job and tastefully done.I wanted to get a Retro Look, and Line-X wanted $750.00 to do the top and hatches. I had read a lot about Raptor Liner (I have no connection with the Company) and decided to give it a try. I used my Kubota RTV to try out the spraying of the liner and had real good luck with it. So I gave the top a shot at it.
Very sharp color combo, well done!I wanted to get a Retro Look, and Line-X wanted $750.00 to do the top and hatches. I had read a lot about Raptor Liner (I have no connection with the Company) and decided to give it a try. I used my Kubota RTV to try out the spraying of the liner and had real good luck with it. So I gave the top a shot at it.
