Mounting Screws for Dash Mount
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
I only needed one, but they're only $8 for 6 so I'll hand them out when I see Broncos.
1/4" Male to 1/4" Male Threaded Tripod Screw Adapter Double Head Stud Standard Mounting Thread Converter for Camera Cage Mount Light Stand Monopo Shoulder Rig Tripod Black-6 Packs
https://a.co/d/axxYIq7
Ford Bronco Mounting Screws for Dash Mount 1679453295206
Moto26
Tucson AZ
How is that supposed to work? What are you attaching to the dash with it?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
darinhouston
Darin
U.S.
GoPro mount
Moto26
Tucson AZ
GoPro mount
So the GoPro mount you're using, does it have an independent swivel adjustment for the actual camera? I'm just picturing a mount with a female thread that you screw this adapter into, and then you screw the other end of the adapter into the female thread in the dash. But once everything is tightened, the alignment of the mount is wherever it ends up, and wouldn't be adjustable at that point. Do you have a picture of the actual GoPro mount you're using?
darinhouston
Darin
U.S.
Standard housing. Added a couple of rubber grommets to change rotation and allow some overturn.
Ford Bronco Mounting Screws for Dash Mount 91B56634-BE5A-4744-81A6-AE9A7AE42F77
Ford Bronco Mounting Screws for Dash Mount 281B8E94-0E71-42D6-982F-FF70DE1320FC
