MY 2023 Build Week Tracking Spreadsheets
Scopebit
Troy
Tricities, Washington
wizardoforange
William
Knoxville, Tennessee
2023 Ford Bronco
I hope I did this right and didn't screw anything up. I'm a good mathematician but I know next to nothing about spreadsheets. I went to the blank line at the bottom of my build week, filled in the blanks, and hit "share". 936 days and counting so far!
66Fan
66Fan
Tim
IL
2022 Wildtrak
Looks like you're good to go on 3-20-2023 sheet!
No need for the "share" button, but it doesn't hurt anything either. As data is entered, it is automatically shared.
broncoj11
Everglades
Trunks
Ford Bronco Everglades
Everglades
My build week says 3/3 but I don’t have a window sticker yet. Does this mean I got pushed back ?
66Fan
66Fan
Tim
IL
2022 Wildtrak
Not necessarily, Stickers usually pop 7 days prior to the actual build/blend date, so if your late in the week of 03MAR, you may still have a chance.
You could also contact the 1-800 number and ask if your build week remains the same, if you don't want to wait the week out.
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
3-13 build week. When I checked the other order tracking on Ford I was listed as 3-17 Friday build and now looks to be moved to 3-15 hump day build.
broncoj11
Everglades
Trunks
Everglades
Below are the currently announced 2023 build week tracking spreadsheets:
Since scheduling announcements are a thing of the past, the below sheets are created in anticipation of scheduling for the weeks listed. If you receive a build date in a week not listed below, shoot me a DM and I will create a sheet.
Also note that some MY 2022 builds have been pushed into MY 2023 build weeks (same thing happened in 2021/2022). There is now a column at the 'end' of each sheet (column AI) which will allow you to input 10th VIN digit for model year.
Bronco Build Week 11-4-2022
Bronco Build Week 11-7-2022
Bronco Build Week 11-14-2022
Bronco Build Week 11-21-2022
Bronco Build Week 11-28-2022
Bronco Build Week 12-05-2022
Bronco Build Week 12-12-2022
Bronco Build Week 12-19-2022
Bronco Build Week 12-26-2022
Bronco Build Week 1-2-2023
Bronco Build Week 1-9-2023
Bronco Build Week 1-16-2023
Bronco Build Week 1-23-2023
Bronco Build Week 1-30-2023
Bronco Build Week 2-6-2023
Bronco Build Week 2-13-2023
Bronco Build Week 2-20-2023
Bronco Build Week 2-27-2023
Bronco Build Week 3-6-2023
Bronco Build Week 3-13-2023
Bronco Build Week 3-20-2023
Bronco Build Week 3-27-2023
Bronco Build Week 4-3-2023
Bronco Build Week 4-10-2023
Bronco Build Week 4-17-2023
Bronco Build Week 4-24-2023
Consolidated sheet (read-only):
2023 Consolidated Build Week Tracking
If you want to add a link to a build week thread, do one of the following:
Method 1) Select and copy the appropriate link above (as pictured below), then paste into the build week thread.
Method 2) When creating the build week thread, click on the "insert link" button (ctrl-K windows/command-K mac).
Once the insert link dialog opens, put the descriptive text in the "Text" area and paste the url in the "URL" area as pictured below, then press insert.
As more weeks are announced, I will create the sheets and post here.
All sheets created with currently known information. If you spot an error/omission, please let me know.
Good luck all!
Uploaded mine to 2/20:)
ColonelAngus
Jon
PA
2023 Badlands, 07 BMW 335i, 05 Saab 9-5 Aero
Forgive me if I missed something (probably did) but when we get bumped back (i've been bumped 3 weeks now) do we just update the original spreadsheet or move to the new relevant one?
66Fan
66Fan
Tim
IL
2022 Wildtrak
You only update the sheet you're bumped from in one spot... mark column D to "Yes", meaning you were bumped from that week. Then, move on to and enter your info in the new week's sheet.
ColoradoBroncoFan
JR
CO
‘24 Bronco Heritage
Scheduled for 4/24 last Thursday and tracker already says it’s now scheduled for 5/1. Can you please add 5/1 spread sheet? Thank you!
broncoj11
Everglades
Trunks
Everglades
is everyone filling out the spreadsheet after delivery? Just seems like a lot of folks from January build weeks still haven’t taken delivery
broncoj11
Everglades
Trunks
Everglades
Bump
66Fan
66Fan
Tim
IL
2022 Wildtrak
On it. Will create new now and update to populate consolidated this week.
