- Banned
- #31
If they pull that, they must think their customers are a bunch of idiots.
These are add-on accessories from your dealer they are making available in the B&P.
You're only option is the $1650 top or the hardtop. I don't see an option to pick the original top that was included in the pressbefore you get bent out of shape .. look closer and you will see that the 1650 soft top is an upgraded soft top made from canvas and not just the base cloth soft top.
go build an outerbanks and you will see
They are updating B&P as we speak. 10 minutes ago on the Black Diamond and BL there was no option listed for an included soft topbefore you get bent out of shape .. look closer and you will see that the 1650 soft top is an upgraded soft top made from canvas and not just the base cloth soft top.
Those are Bimini tops
I haven’t had a chance to look yet but I know that sometimes the B&P does not switch between 2 door and 4 door when toggled and the selectable options on the right show a 4 door.
No it's not. The "backflip" is just the Sunrider from BesTop. It is an accessory and doesn't replace the MIC top. When installed, it replaces the two front panels of the MIC. And it opens just as the name that the rockstars implies - backflip.Those are Bimini tops
Not for $1650Those are Bimini tops
The front panel Bestop sunrider is listed as an accessory that costs $1,299. The Backflip is listed as a roof option for $1,650. Obviously we can't rely on anything in the B&P but this appears to be different.No it's not. The "backflip" is just the Sunrider from BesTop. It is an accessory and doesn't replace the MIC top. When installed, it replaces the two front panels of the MIC. And it opens just as the name that the rockstars implies - backflip.
For the BesTop Fastback, it also opens in the Sunrider fashion (doesn't collapse all the way to the back like the factory Moar Door ST). Or it can be configured safari style with the rear windows removed. It obviously replaces the entire MIC when installed.
But in either case, none of the options replaces the factory MIC top.
