NEW Superchips Flashcal 1546 Handheld Tuner for 2021+ Ford Bronco
RonM0710
Ron
Spring City, TN
2018 Ford Edge; Suz. XL7
I'm also interested to know if the problems were sorted out, and if the module needs to remain plugged into the OBD port, or it it is removed once you've made the changes you want.
Remove after making changes.
CT203
Connecticut
'13 JK
Well, got mine today and everything works except the tire size adjustment (the main thing I got it for). Everything else changes without issue, but every time I try to adjust the tire sized to 36.5, I get a 'Service AdvanceTrac' warning and it will not go away until I switch it back to 'stock'.
I've followed the onscreen instructions to a T and the other things changed just fine. Any ideas why it's doing this????
I’ve used these with the their vehicles and if it was acting weird, there sometimes were software updates. Hopefully there will be one for you and you’ll be set. Pretty annoying that the one thing you wanted isn’t working.
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
I get get the update app on my MacBook Pro to work correctly either, lol
Esmeral
Edwin
Miami
Tesla Model 3
I used flashcal superchips to resize tires after installing a set of Sasquatch takeoffs on my non-sas BD. With the original setting (32"), my speedometer showed less speed than actual, like 3 mph less than the gps at 60mph. I set 34.5" (closest to 315/70/17) and now the speedometer shows 4 mph above the gps. Has anyone had this accuracy issue with this device?
SuperFord
2013 Ford Fusion
I'm reading that the FlashCal doesn't work on 2023 Broncos. Is that accurate?
(UPDATE: I just got off the phone with Holley/Superchips tech support. As of today 4/21/23 this product does NOT support 2023. The rep I spoke with claimed that "they are working on it" and he estimated that an update should be available "in the next few months".)
OG-Surfdog
Joe
Princeville, Kauai, Hawaii
www.the65falcon.com
'65 Falcon, '74 TR-6, '13 F150, '21 Mach-E
Since I’ve used this already and my PC is showing VIN lock not used, I should be able to use on another Bronco I would assume. Anyone tried that yet?
I just bought a used SC Flashcal 1546 for Bronco.
The original owner said he put his bronco back to stock.
Will that allow me to use the device on my 2021 Bronco ?
Or did I find too good of a deal on this unit?
New Edit:
Yes with his bronco set back to stock I SHOULD be able to get it on my mine!
Whew....
21Bar
Ryan
AB
2022 Sasq Outerbanks
I am looking at purchasing to disable the Auto Stop and avoid pulling my dash apart to install a HW solution. Does anyone know if this will allow me to change the units on my boost gauge from kPa to PSI?
OG-Surfdog
Joe
www.the65falcon.com
Yes
It does disable the ASS (Auto Start Stop). And the annoying double honk feature. And you can choose your unit of measurement for Pressure. However I can't seem to dial in the tire size to get an accurate speedo reading.
Since I have the Sas package I thought 35" setting would do it, but it reads fast on the speedo by 3-4 MPH compared to a GPS app I'm using. I tried all increments by a quater of an inch available in the device. All the way down to 33.75" even. Still reads fast, its closer but no cigar. There is also a "Return to Stock" setting. I'll try that next, assuming the Bronc knows it had 35's (34.6") and that may be the best setting to begin with.
Chime in those who've been there and done that!
21Bar
Ryan
AB
Yes
Thanks, I'll get one ordered. I can change tire pressure to PSI in settings but not boost pressure. It costs a bit more to diasable the auto start/stop but with my luck I'll break something taking the dash apart to put in a HW module.
OG-Surfdog
Joe
www.the65falcon.com
Oh Oh Hey,
I was refering to tire pressure. Didn't see anything in there about boost pressure.
Just to clear the air.
They give all the things it can do on their website. Pretty complete list. I would check that 1st.
21Bar
Ryan
AB
Thanks for the clarification. I’ll still get one for ASS disable
Danh63
Dan
Ohio
BMW X4, BMW 840, Chevy Trailboss
So someone mentioned it doesn't work with the 2023's?
Treich
Tim
F250, F250
(UPDATE: I just got off the phone with Holly/Superchips tech support. As of today 4/21/23 this product does NOT support 2023. The rep I spoke with claimed that "they are working on it" and he estimated that an update should be available "in the next few months".)
Thanks for doing the foot work I am waiting for my 37s to come in and been looking at this over playing with Forscan.
Superchips_Mktg
Superchips_Mktg
Jacob
Ogden, UT
www.holley.com
2022 Bronco
any news on the update. or any idea when the update will be out?
We are actually just finishing up validation for the 2023 as we speak. Every feature on the current device will work with exception of the start/stop, so you could order one to do tires and update it after we release 23 support to get that start/stop feature working.
