No order changes after VIN # issued
Kris87
K
Georgia
ford f-150
The way that reads is that they will be adding things over time... so it won't show in B&P when you submit the order. I suspect that they will allow changes to your order to add these if you are say, at least 60 days out from expected delivery (wild guess there).
No changes once a vin# is given. Unless you know someone way up the chain.
jayhawkco
Aurora, CO
2006 Nissan Xterra Off Road
In your opinion, how far out from delivery would you expect VINs to be assigned?
Carolina Jim
Highlands
2021 Bronco 2-door
Kris...2 questions please:
Only 50% of dealer’s orders are going to be automatically given allocation (other factors can increase that number). Who determines which dealer orders are given allocation: dealer or Ford? If dealer determines, what process is used? If Ford determines, I assume it is timestamp driven?
Are orders created Dec 1 treated any different than Jan 1 orders?
Kris87
K
Georgia
ford f-150
Long ways from actual delivery. Orders are accepted by Ford every Wednesday normally by 10pm. If they accept the order, it's assigned a vin by that Friday. If not, definitely by the next Friday. It's quick, so better get your order right out of the gate.
jayhawkco
Aurora, CO
So if December 1st is order day, I finalize my order with my dealer at that point, they submit it, there isn't any changing after that I assume?
Kris87
K
Georgia
ford f-150
Not really. I outlined the days of the week in the previous post how orders are picked up. I guess you could have a day or two if the stars aligned. But bank on the answer being no.
Bronco4lyfe85
William
2019 Challenger Scat Pack
Someone else said vin is assigned 7 days after your order is pulled. So you would have months between ordering and when your order is pulled, especially if you’re an October reservation.
ColoradoGuy
So guessing that the comment in the freep article is unofficial. I don't see how they could add things for the later reservations because they have already put their order in and mostly likely have a VIN assigned.
Raptor911
Raptor911
Broadlands, VA
I don't think this correct. I have ordered 3 Fords. It goes something like this:
1 - Dealer takes your order then submits your order to order bank
2 - order gets pulled from order bank
3 - 7 days after your order gets pulled it will be assigned a VIN
4 - your order will get a build week
5 - when build week gets closer, your order will be assigned a build day ... your vehicle's birthday
I need to dig through my notes and then I will create a thread so everyone can see the process.
BTW ... I left out a few details above. For example when you get your VIN, you can view the window sticker online. At this point it is CRUCIAL you check your window sticker to see if any mistakes were made. If a mistake was made by the dealer and NOT you, Ford will submit an emergency order to the order bank with a priority of 1 which would move this order to the top and thus it gets pulled right away.
Also .. when your order is in the order bank ... how do you know when it gets pulled? There are 2 ways: Ford has a twitter account and you can ask them. They would need to know your name and the dealer you ordered from and then they can check. OR the dealer can tell you as he access to the ordering system where he can see updates to your order
Again .. I need to check my notes and I will post something.
Danager
Dan
Canada
2019 Ford Edge
I believe there is an additional step in there. I’ve ordered 8 times. I understood the VIN was not assigned when the order was accepted. The VIN is assigned once assembly is scheduled. Perhaps on some vehicles, trims, options cause this to move quicker or slower. One F150, and one Fusion, I made changes approximately 1 month into the order.
Kris87
K
Georgia
ford f-150
I outlined exactly when orders are pulled, day of the week, the time at night, and when vin# is assigned. We order almost 7000 Fords a year. I promise it's right.
broncoj11
Everglades
Trunks
Ford Bronco Everglades
Everglades
wait, is everyone that made a reservation (that places an order) not booing to get their bronco? or is that just allocation per wave of production
