Noise behind the speedometer.
Squashed
Jon
2019 F150, 2020 F150
Yes sounds like a dry tach cable. I have not spent any time looking for it but it's at highway speeds and it sounds like a loose wire harness. I have checked in the engine compartment and did not find anything.
PWillette
Parrie
Maine
I would add, that since I was their guinea pig for this repair that if you went there, they could do it fairly quickly.
Thanks for the follow up. Good to hear the fix worked. Darling's in Bangor is my dealer, trying to find out if they have done any before I commit.
JC2DR
JC2DR
Joseph
Maine
Bronco Base 2dr 2.3 7speed
Thanks. I'm headed to the dealer in the morning. I'll get it looked at.
Groundhog
Ozark
'22 Wildtrak, '21 OBX
Following... I have same issue at highway speeds. Sounds like a wiring harness or cable flapping in the wind behind the dash on drivers side; doesn't seem to be directly behind the instrument panel though, seems to be lower than that.
JC2DR
JC2DR
Joseph
Maine
Thanks exactly the sound. As for location. lSeems to me behind the dash at the speedometer, but I can't say it's there exactly.
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
Thanks..guess I don’t need to check speaker then. Mine is not loud yet
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning, Mark! I would be glad to help you out with with these noise concerns if you'd like. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
Squashed
Jon
Any updated information ?
JC2DR
JC2DR
Joseph
Maine
Having it in the dealer on Wednesday. They need to recreate it, (which shouldn’t be too difficult) then we go from there. Should be easy enough though.
Squashed
Jon
Please post what the find so I can check mine out .
Squashed
Jon
I think I found it. Was changing the oil and went in deep. I belive this the the front diff vent line routed with 0 wire ties behind the top inner fender bracket.
Groundhog
Ozark
I think I narrowed this down to the painted plastic covers used on the windshield frame mounts. I wasn't hearing the noise every day so I waited until it was pretty obvious to pay closer attention. I pulled them off a couple of days ago and the noise disappeared. Trying this solution out - added some stick-on foam to the covers. I'll report back in a week or so.
Ford Bronco Noise behind the speedometer. PXL_20231215_133813895
Ford Bronco Noise behind the speedometer. PXL_20231215_133626677
Ford Bronco Noise behind the speedometer. PXL_20231215_133620696
buzzcutt2
FL
Is this driver or passenger side? I have a similar noise.
Ford Motor Company
Dearborn
Hey there! Can you please send us a PM with your VIN and dealer name/location so I can look into this speedometer noise concern for you? To send a private message, just click on our username and select "Start Conversation". I'd be happy to see what I can do to assist!
