OEM LED Taillights retrofit on a regular halogens?
bobogto
Chicago
M5
Hi all,
Could not find anything about this.
I like the look of the LED tail lights, but I like the retro look of the yellow front parking lights, so I opted out of the factory LED. And also, Ford build electronics... I was kinda skeptical.
Has anyone tried to simply install LED on a non-LED Bronco taillights. Is it plug in play? is it even possible?
Can anyone with LED taillights may be post a picture of connector and light assy? That way I can at least figure out connections and go from there about needing a reprogram or something.
Thank you all!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Hi all,
Thank you all!
I think LEDs use a different resistor. Might want to check for adapters.
JP_Oracle
JP
Metairie, LA
21 Bronco
Hi all,
Thank you all!
They plug right in but you have to make a few changes in FORscan. Our Flush Tails available for pre-order now give a similar look with a brighter reverse light, will be plug & play with your halogen set up, Flush to the body design eliminating the potential of damage, AND the set costs 1/2 of what it costs to buy 1 side LED Signature Tail Lamp from Ford.
https://www.oraclelights.com/collections/ford-bronco-products/products/bronco-flush-tail-lights
ORACLEJP10 at checkout for 10% off!
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
LOL. The truck is absolutely laden with "Ford build electronics", and the thing you're worried about was the LED tail lights?
bobogto
Chicago
M5
Exactly I don't need one more.
bobogto
Chicago
M5
I already looked up your option, but I understand you have some supply issues and If I have to be completely honest, I don't really like your design. That's just me. Depending on cost and complexity I might end up with yours but at this point I wanted to find out how hard will it be retrofitting the OEM LED taillights.
JP_Oracle
JP
Metairie, LA
21 Bronco
Respect! (y)
