BroncoJones
B
GA
'02 Yukon
Exactly what I thought, 2-3 MPG hit each for the 2.7L or Sasquatch. A little surprised the BD robs 4 MPG off the 2.3L HWY number though. Sheesh. I may just keep the OEM tires on my BB.
Probably not just the tires alone. It's gonna be heavier with the steel bumper/plates and the stock 4.7 rear differential doesn't help maters.
I'm not blown away with these numbers but I am Ok with them.
NCOBX
H2 Hummer, Holden Commodore
If these are the official imaginarily good numbers, I might be giving those old gas guzzling V8's a run for their money when I put my foot into the fun pedal.
At least it will have 400+ftlb of torque.
I’d rather put them up against a modern V8 that’s not gas guzzling with 400+ftlb.
KDAber64
Kent
AZ
2014 F 150
Considering my 5700 lb F150 with a 5.0 and 34x11.5 AT w/3.55 gears gets 17.2.... 17 for a SAS 2.7 sounds about right.
beachman101
;pkl
While im happy the numbers are not officially dumpster shit 15mpg
with these numbers there is OFFICIALLY no reason that ford should not put the 5.0 coyote in the car
none
at all
the whole "eco" ford thing is out the window. Its a performance off road car now give us the v8
Brocked
Brock
H-Town, Texas
Lots
As aerodynamic as a Barn Door, heavy, big tires and high gearing. What are you expecting?
Ford also sells the Mach E if you cannot take 17 mpg. Still gets 5 mpg better than my Tundra Pro.
NCOBX
Is that the new 5.0 with cylinder deactivation? (2021+)
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
2.7 with 3.73 gears OBX should get 21 mpg :):eek:
My Taurus limited only gets 22, so these numbers for OBX 2.7 do not scare me at all.
xcxv
hmm
Jeep Bronco
numbers must be lower with regular gas
KDAber64
Kent
AZ
2014 F 150
