Oil filter relocation completed
Pygmy Warrior
Georgia
2024 Bronco 2.3L , 2023 Bronco 2.7L
After performing the first oil change on my 2.3l, I will be adding this before the next oil change. Thank you for the info!
Pygmy Warrior
Georgia
The Derale 25708 notes an in and out in the casting. Does the Derale 35703 have it as well?
Thanks!
kodiakisland
Arkansas
It’s cool and all, but seriously don’t understand the need. I have no problem reaching straight in and removing the filter. This is one of the easiest filters to remove on anything made in the last 20 years that I have changed.
I simply reach in with my right hand and remove. Less than 5 minutes to remove and replace with no drip or mess whatsoever.
Maybe it’s easier with a lift instead of stock suspension, but it’s so easy through the wheelwell?
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
I guess you don't have 37x13.5's and aren't 6'1 @250# with minimal body fat.
I don't fit in my wheel well. šŸ˜‰
I wish the 4d's front doors were bigger too. I sit behind the B-pillar while driving.
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
Thanks!
I don't know, but it's easy to see which is which when it's in your hands.
Btw, We're over 53K miles and no issues.
kodiakisland
Arkansas
Nope, just 35s and far shorter arms. We’ll see when I go to 37s if it’s as easy.
For me it’s just right there:
Ford Bronco Oil filter relocation completed IMG_4189
coffeetwitch
kansas city
bronco
Finally got around to installing this at my last oil change. also have forscan lite. does anyone know what normal engine oil pressure is for this engine? like an idiot, i did not grab a base line before mod.
Sidney073
Sid
Jacksonville, FL and Sebring, FL
2023 Ford Bronco
About how long did it take you to do this conversion, and can you post a picture of the relocated (2nd) Oil Filter Mount?
I think you did a great job, and it looks great too.
Luthier419
Shannon
State College, PA
Bronco, F150, Fiesta
Mein Gott……
I didn’t know the 2.3’s had a can filter.. but when i saw this…. I thought… i wonder…..
yep….
there’s a ready made kit to relocate the filter on the MK 7 fiesta to a place where you can actually get at it…
i’ve got 270k miles on the thing… just ordered a new timing belt and water pump.. gonna order that too…
50+ oil changes over 12 years…. I i just kept bitching, swearing, twisting and grunting every time i changed the oil?
Sidney073
Sid
2023 Ford Bronco
As someone who does his own maintenance, I was a bit underwhelmed at the side access past my 35x12.50's. Sure, you can crank the wheel and reach in there, and there's kinda enough room to wiggle past the brake lines if you use your left hand... But why? šŸ¤¦šŸ»ā€ā™‚ļø
So I took a trip to the Amazon jungle and found the needed stuffs, then went out in the shop and whipped up a mounting bracket that slipped into the rear crash bar sleeve. Drilled the needed hole to retain it with a 1/4-20 bolt, and whipped up the two -10 hoses.
Voila! No more trouble changing filters. šŸ˜Ž
I did make one change after these pics were taken. I moved the filter base down on the bracket so the 45° AN fittings weren't so close to the firewall. The filter is still tucked nicely above the bottom plane of the frame out of harms way.
I also debated mounting the filter horizontally (like on the engine) so cracking the seal dumps the oil down, but I've taken a liking to stabbing the bottom of my filters first, and that resolves the oil cascading around the cannisters when you spin them off, and vertical mounting allows pre-filling the filter.
