Overhead Squatch Basket aka Sunglasses, Mic, small MOLLE pouch holder
Squatch Parade
Mickey
Montreal
2021 FE
why are they calling it a sasquatch basket but putting a velociraptor in it?
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
Just bought one! My Aux switches were removed from my order without my consent so I had to go aftermarket! Ended up with Switch Pros 9100 that I mounted to the face of the glasses holder, thinking that will be a nicer look when installed with the SP9100 mounted to it.
Mountains2Metal
Mountains2Metal
Nick
Eastern, NC
2012 F-150, 67 Bronco, 94 Range Rover
Looks sweet, however looks like the hardware goes in the 2 cutouts in the front you won’t be able to use a sunshade ? Doesn’t seem that the 2 hooks would be enough tension to keep the cubby secured.
It depends on the size of the hooks. You can fit the smaller hooks to the side or back of the opening after the squatch basket is installed.
Keeping you on your toes!
Easy-v
U S A
BadSquatch
I ordered one and cut some toolbox liner and stuck it on the inside of the basket to keep stuff from sliding around and it keeps the noise down too
EveryDayBronco
Motorcycle
I like this concept have some questions:
- does the thickness of the material affect how well the mic top gasket seals along the top edge> - do the two mic fasteners need to be adjusted for thickness of the material?
We first showed this off at the Super Celebration East and recieved a lot of complements! We had put the prototype on the Bronco that morning and drove to Tennessee. We ended up changing the design and had to wait until now for various reasons. Anyways....Check out the new Squatch Basket from Mountains2Metal. This helps complete the inside of your Bronco while adding extra overhead storage space for your sunglasses, Mic, Radio, etc. Uses factory mounting locations and fits right in front of your auxilliary switch location. Easy Install only takes a few minutes!
https://mountains2metal.com/BR6OHSB/
I like this concept but have some questions:
- what material is this made from, steel, aluminum?
Thanks!
Mountains2Metal
Mountains2Metal
Nick
Eastern, NC
Thanks!
Through testing and feedback, the thickness has not had any affect on how well the gasket seals. The two front latches are a little harder to close but not difficult. The squatch basket is made of steel and is powder coated black.
AaronW
Aaron
Phoenix, AZ
@Mountains2Metal Where did this go? Looks like it is no longer available on your website.
Cody@Mountains2Metal
Cody
Wilson, N.C.
2021 Ford Bronco 2D Manual
AaronW
Aaron
Phoenix, AZ
Boo still not working
Ford Bronco Overhead Squatch Basket aka Sunglasses, Mic, small MOLLE pouch holder IMG_2298
