Rydfree
Benny
Alabama
I'm confused. Cyber Orange is a great color that shows off the lines and makes the MIC look good. But then it's off your list?
If you read between the lines it says he just doesn't like school bus yellow . ;)
Rydfree
Benny
Alabama
Thanks for measuring the tires. Shows why the overland squatch has less fender clearance. Real 35s will be stuffed.
The overland was a stock BL Non-Squatch .
Raptor911
Raptor911
Broadlands, VA
Then I will give you more my brother:
Titan7: Forged, light and super strong. 17x8x5 and weighs about 20.6 pounds. When paired with duratracs, I am about 10.5 pounds lighter per corner.
I am running them on my 2019 Raptor. There will be an application for the Bronco and I plan to run Bronze wheels with either CG or Area51:
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605579501071
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605579548338
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605579557493
nvm the tire i LOVE that rim!!
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605579522584
Incognito
Incognito
Phoenix
2017 jk
@Jman19
It's a great color if you love yellow to orange .
It shows off the Bronco lines and "pops" great.
It was not "me".
Not the same as saying it ruins the lines, or doesn't draw your eye.
Black looks like crap on the Bonco.
It hides the body lines and makes it look like a rolling brick.
See the last pics in the OP .
buzpro
Binky
Tacoma
I am running them on my 2019 Raptor. There will an application for the Bronco and I plan to run Bronze wheels with either CG or Area51:
what's the offset on these rims?
Raptor911
Raptor911
Broadlands, VA
-1. the wheels I am running on my raptor were never designed with center caps. Titan7 is working on a version 2 of that rim that will have center caps. They are waiting on the bronco wheel specs and then they finalize specs and will produce a bronco application.
bdub2you
Alexandria, VA
Nice pic comparison. The Bronco is a wide arse biotchie.
That is why IMO the Wrangler will fair better on trails and the Bronco will be much more comfortable on road. Select between these two excellent vehicles available for your purpose.
The Bronco is 5.5 inches wider than an a Rubicon. If I'm on a trail where that 5.5 inches will make a difference then I'm willing to bet I've already said F-it, yolo.
jxc
Joe
Chester County, Pennsylvania
Accord/CX-5/A5 Cab
USMC_n_philly
Deno
Philadelphia
6G Mustang
thanks for this.. indeed been saying CG is for me .. cause it seems like it changes in the light.. I have seen it look longer Carolina Blue as well.. once that white top is dropped n 2021 its over... OB n CG...lovin it...
Toccoa
Isuzu Rodeo Sport
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605583939947
More tire or less flair. I'm leaning towards swapping out to the standard flairs.
