- #16
@Beach_Bum I went with the bilstein sasquatch coilovers. I pulled the both crash bars before I brought it in to get the tires put on. I have not tried to put either back on.
@Tricky Nick Its been a while since I did it. I think it was a very light touch with a screw driver until the plastic screw started to move from its base and then I used a small pick tool to help pull on the screw head to keep tension on the threads.
Are you saying they use the plastic fender clips to hold that bumper in the tailgate? Those things are the pits. I need to find a bulk replacement for them. I’ve had to take the wheel liner off twice now and have to again and only half of them make it out alive.I failed, stripped the plastic screw head and no luck removing. No big deal, as they can wrap around them, and it will be behind a spare anyway. Thanks for the help though!
Yeah they're the screw version of the 2 pc push pins. Have to be super gentle with them. Ford loves them.Are you saying they use the plastic fender clips to hold that bumper in the tailgate? Those things are the pits. I need to find a bulk replacement for them. I’ve had to take the wheel liner off twice now and have to again and only half of them make it out alive.
They’re the worst. I found a push/pull replacement at AutoZone/Advanced that worked perfectly - but, they’re like $4 for 3 of them. I need to find out what they are again - I think they were labeled for Honda or something - and find a bulk supply on Amazon or something.Yeah they're the screw version of the 2 pc push pins. Have to be super gentle with them. Ford loves them.
How is the west and ride? I’m thinking those but leaning towards the MT Baja Boss in 35x1100@Beach_Bum I went with the bilstein sasquatch coilovers. I pulled the both crash bars before I brought it in to get the tires put on. I have not tried to put either back on.
How quiet/civil are they on the pavement?@mcinfantry the ride is good. I run the tires pretty low ( upper 20's). I think it handles well for what it is. I do not expect it to be a sports car. The tires at tread surface are only 1/4-1/2" wider than the stock general grabbers. They tuck in pretty nice under the fender.
