Pizza cutter 35" spare - rubber bumpers?
BaseBD
Wisconsin
2021 4D Black Diamond
So I went with 35x10.5r17's on my black diamond 7MT. They look a little stuffed. I haven't been able to check clearances yet. Been a busy weekend. I am intending on swapping out the Hitachi coilovers for a set of Bilstein Sasquatch coilovers as soon as they become availibe.
I got the tires mounted on Friday and they look great. Tire shop forgot to order 5 tires for the spare so that it getting done tomorrow. Since these are "narrow" tires I didn't think much about mounting the spare except to get the 3rd brake light relocation kit to clear the bigger tire. Because I have a long trip at the end of this week I test fit one of the tires on the spare bracket. It fit.....but.... I had to remove these rubber bumpers. I have not looked closely at sasquatch builds. Are these on there at the same thickness? I am thinking that I could just shave ~1" off the bumper and reuse it if needed. Tire sits solid on the mount without it. I am assuming it is there to help control motion at the edges of the tire?
Thoughts?
Ford Bronco Pizza cutter 35" spare - rubber bumpers? 20210910_165806
Ford Bronco Pizza cutter 35" spare - rubber bumpers? 20210912_213557
Ford Bronco Pizza cutter 35" spare - rubber bumpers? 20210912_213609
Dillhole
Andy
Van down by the river
2012 Jeep Wrangler 2dr
First off, she looks great!!
Yep, it's there to prevent extra movement to mitigate any flexing of the carrier and/or tailgate to prevent stress damage. Aftermarket will eventually step up and fill this void but if you need to make it smaller I vote a simple but well calculated trim would get the job done. I had to go the opposite way with my Jeep and get longer ones made by Daystar to counteract the new offset, another option for extending is the old tennis ball trick, just shove one in there.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I had the same issue when I upgrade my Base tires that are 10" wide to new tires that are 11.2" wide. I took a sharp razor blade and simply trimmed about a half inch off the bumper and left it in place. I think this is probably better than removing it completely.
broncbeau
Beau
15 Sierra
More pics man!!!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Does looks great with 35.
Perhaps next summer for me. My short ass is gonna needs side steps 😆
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Since you already have the RC relo for 3rd brake light, you might ass we’ll add the spare tire relo as well..
BaseBD
BaseBD
Wisconsin
I am debating the spare tire relocation or just adjust the size of the rubber stops now. I will hav eot look at the curve of the 3rd brake light bracket and see what moving it up another 2 inches does. What I found yesterday when I put the relocation bracket on is the bracket now pushes on a the soft top when it is in the full down position. I forgot to get a pic of that. I wonder if the spare tire movement up will make that better or worse.
evilletruck
Bill
Evansville IN
2006 F350
Depends on your offset as well I went with 35 x 12.5 but with a 0 offset so I have the opposite issue where the spare is too far away from the bump stops.
If you know you are going to keep that same size wheel and tire set up just trim the stops, if theres a chance you may want to go to different size or offset down the road you may want to go with the relocation kit.
BaseBD
BaseBD
Wisconsin
So I am going to meet in the middle for now. I ordered some Jeep spare tire bump stops on Amazon for cheap. I will shave those down to the correct height. Then if I go different rims in the future I will still have the original stops if I need to relocate the spare tire bracket. Thanks for your help on here! I will post pics when I finish it up tomorrow.
Broncola
Hawaii
Element, ‘75 Bronco widow
I ended up trimming mine, but had to do it still installed on the bronco. I’m sure I could have yanked it off if I tried hard, but couldn’t get it to unscrew like it looks like you should be able to do. Any tricks to removing them? Trimming on the rig was a pain and can’t say I didn’t get my first little nick in the paint.🤯
Thoughts?
Ford Bronco Pizza cutter 35" spare - rubber bumpers? F5212DC1-68C2-4990-877A-0646C1E06D0D
Tricky Nick
Nick
St Charles, IL
2009 2dr JK, manual, AEV lifted, 35’s
Any luck figuring out how to unscrew / remove the rubber spare bumpers? @BaseBD ? I am going to drop off mine tonight for full PPF, and wanted to remove them and re-install after the wrap.
BaseBD
BaseBD
Wisconsin
@Tricky Nick Its been a while since I did it. I think it was a very light touch with a screw driver until the plastic screw started to move from its base and then I used a small pick tool to help pull on the screw head to keep tension on the threads.
Tricky Nick
Nick
St Charles, IL
I failed, stripped the plastic screw head and no luck removing. No big deal, as they can wrap around them, and it will be behind a spare anyway. Thanks for the help though!
Beach_Bum
Ken
St. Augustine, FL
Thoughts?
Yes, I know this is an old thread. But I wanted to see if you have any updates as to whether you added a lift or just a set of Bilstein takeoffs as you alluded to. Prior to any lift/suspension upgrade, did you have to remove the crash bars for fitment on the stock +55 offset steelies? I see the front crash bar but can't tell if the rear was removed. Was there any rubbing at lock? I really dig the pizza cutter look. Also, more pics please.
