Ply number on the stock Sasquatch tires?
WeirdGuy
Austin
Galveston, Texas
Base Sasquatch
  • Thread starter
  • Banned
  • #1
Does anyone know the ply number on the stock Sasquatch tires?
WeirdGuy
WeirdGuy
Austin
Galveston, Texas
Base Sasquatch
  • Thread starter
  • Banned
  • #3
Thanks!
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
X2: 6-ply rated.
Six-ply rated, meaning...?
This thread may overlap the long (high-complaint) thread (14 pages and counting!):
https://www.bronco6g.com/forum/thre...on-my-new-bronco-goodyear-ford-or-both.59377/
I explained in a long post there that I had three flats on well-maintained unpaved gravel + hard dirt roads in Utah--after handling some grungier trails in Moab without a problem. The repair guy I used in Wendover said 6-ply ain't enough: the stones the tires grab work up and through the six plies. (Plys?) His advise was to air down, and eventually replace them with 10- or 11-ply. So, Mr. Discount Tire, a few questions:
1) I'd rather not go to the increase in weight a higher-ply tire would call for. Thoughts or suggestiongs?
2) One poster said those Goodyears don't grab rocks as much after they've worn down.
3) What psi is best for firm unpaved roads on the GY Territories (Wranglers) which can accommodate a 50 mph cruise speed?
4) And what does "six-ply rated" mean, anyway?
SuperDave150
Albuquerque, NM
Ford F-150, Ford Edge
3) PSI: Anyone who answers anything but what the manufacturer recommends is opening themselves up to potential legal liability issues.
4) "six-ply rated" is like “one-ton truck”. It harkens back 50-75 years ago to an era when these had meaning but now they are replaced by real numbers, such as tire load index, or truck GVWR. Nevertheless maybe someone can read the sidewall of their tire and tell us what the fine print says regarding construction.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
I'm sorry to hear about the multiple flats @BostonSasquatch and my apologies for the lack of clarity in ply rating.
A tire’s ply is an older term referring to the internal layers of a tire’s construction, such as in the early days of bias ply tires. The more plies gave a tire a larger load carrying capacity, so manufacturers would count the plies and use this number to denote this measurement.
However, modern tire construction uses fewer, stronger ply material. Therefore, load range today simply defines the tire’s maximum air pressure, as opposed to specific information about the actual plies.. Using "C" for example, this Load Range indicates that a tire is equivalent to a 6 ply construction tire. This tire isn’t actually built with 6 plies, but rather one or two plies of equivalent strength.
I'll add that tires are pneumatic, and vernally speaking, the higher the pressure the more load carrying capacity.
Regarding pressure off highway, if you choose to air down, it's going to boil down to personal preference as there is no magic formula when it comes to the right air pressure. For us, we recommend the pressure that meets the load capacity of the vehicle per the load inflation tables.
Braaap
NJ
Outback
WOW, a 6 ply sidewall? That's excellent. Thanks for clearing up how many plies a Sasquatch tire has.
BostonSasquatch
Randy
Boston
Thanks! As you may have guessed, I'm on a learning curve here. I'll pose a question to you and other board posters: Have you found that with a bit of wear the Goodyear "Territories" are less prone to grabbing and chucking rocks? And if so, at what kind of mileage and/or wear? Just wondering if I should fork up $$$ for new tires next spring. I'm at 15K now, with maybe 1.5K off-road (trail & various grades of unpaved).
joeb
Joe
Pennsylvania
FJ Cruiser
Following Thread
Though I have always been a fan of the bf ko2's with my 4x4 vehicles. -- and I think they come in different Load Ratings. So I hope to learn something. I have seen C and I think E Load ratings
If someone can compare the differences, that would be great.
Thanks
Braaap
NJ
Outback
The factory Goodyear Wrangler Territory MT 315/70R17 tire ply (taken from the sidewall) "Plies Tread 2 POLYESTER 2 STEEL 1 POLYAMIDE & Sidewall 2 POLYESTER"
