Rattle-clicking passenger side soft top
kbarron
Keith
Dallas
Ford Bronco
I have this rattle/click above passenger soft top where it clicks in with pull lever area, I have looked at all forums and I have tried the all tricks I can find on here and it keeps coming back, sometimes it doesn't one ride then out of the blue it comes back just want stop. doesn't do it when top is pulled back. I am at my breaking point.
1. tried heat wrap round entry pin helps a little but doesn't last.
2. tried velvet tape around the entry pin whole
3. tried adjusting the soft top in the back to make sure its flush on pins
4. windows down or up same clicking noise
Gangstead
'21 BD 4DR 7MT Soft
Wish I knew. I think I have the same problem on mine, but on the driver side. Right behind the driver about where the latch is. Won't happen for a long time, then I'll put the top down and when it goes back up it rattles/clicks on every micro bump on the road. Hope we can find an answer here.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! I can assist with your rattle concern on my end. Please send over a DM with your VIN and Ford dealer info.
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
Any update on this? I have the same issue in the same place. Loved to know what they diagnosed it as.
MattyAg
San Antonio
I had a click/rattle and found it to be the plastic on the soft top above the roll bar (above passenger side window). There is a piece of felt on the thin plastic and I think it wasn’t installed quite right. When going down the road I think wind catches the thunder plastic and bounces it off the soft top or the roll bar. I ended up just shoving a balled up napkin above the door between the soft top and the roll bar and the clicking stopped. Hope this helps.
threeonone
Canada
Jaguar
Does it sound like this? Mine has been a year and 7 trips to the dealer and they can't figure it out. I'm dying to fix this. It happens intermittently but you can see it's annoying as all hell.
kbarron
kbarron
Keith
Dallas
Ford Bronco
I believe I found the issue at least for me, I put a piece of Velcro tape on outside of plastic piece covering the lock in henge, see pic
Ford Bronco Rattle-clicking passenger side soft top pic
RaceRedOBX
Brock
Louisiana
2017 F-150
Mine rattles and has a wind gap above the passenger rear door. Mine is definitely coming from the latch above the door, as I can replicate the sound by pushing/pulling on the frame.
Ford Motor Company
Dearborn
Hello, Brock! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this rattle concern. Thanks!
Ford Motor Company
Dearborn
Hi Keith. Can you send us a DM with your VIN and dealership info? I can look into this for you.
threeonone
Canada
Jaguar
Ford Motor Co, my Bronco has been into the dealership 7 times for this rattling noise and they can never fix it. It's driving me insane.
Spencersample
Spencer
Canada
Did you ever get this fixed? I think I have something similar on the driver side. I thought it was coming from the door though!
Capone7532
Colorado Springs
2022 Ford Bronco
I found this on mine, it may be your problem as well.
Riptide
Richard
Phoenix
I noticed this in mine too. Only on the right side. The left doesn’t do it. I’ve been trying to find the cause of that clicking noise and it’s been driving me crazy! Where you able to fix it? If so, how?
Deleted member 49144
Guest
Did you ever find a fix for this, I have the exact same thing and it’s driving me insane. 🥴
