REDLINE TUNING Hoodshocks
  • Thread starter Deleted member 31057
  • Start date
  • Watchers 1
broncoky
Jacob
Lexington, KY
2021 Bronco 2DR CB OBX SAS & 2000 Lexus LS400
Have these as well. Defiantly recommend the upgrade!
Redline Tuning
F-150
Thanks everyone! We recently became a Sponsor on the forum and are here to answer any questions!
Redline Tuning is pleased to be a sponsor on the Bronco6G forum and want to showcase our 100% Bolt-In Hood QuickLIFT system for the Bronco. Our system is the ORIGINAL Bolt-In system for the Bronco and installs in less than 10 minutes with no modification required to your vehicle or for you to un-bolt you hood to mount any brackets. We offer two different lift heights for the Bronco. Our standard QuickLIFT system raises your hood to the same height as the factory Prop Rod and our Max Lift system raises the hood 8 inches higher for maximum access to the engine compartment. Both systems are available in PLUS, Carbon and ELITE versions as shown below.
Ford Bronco REDLINE TUNING Hoodshocks bronco-maxlift-
Ford Bronco REDLINE TUNING Hoodshocks bronco-quicklift-plus-
Ford Bronco REDLINE TUNING Hoodshocks bronco-maxlift-plus-
QuickLIFT PLUS features:
* All black powder-coated mounting hardware
* Black e-coated gas springs
* 4 year warranty
available directly from our website here:
QuickLIFT (same height as stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11040-02.htm
MaxLift (8" higher than stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11039-02.htm
Ford Bronco REDLINE TUNING Hoodshocks bronco-maxlift-carbon-
QuickLIFT CARBON features:
* Black e-coated gas springs with real carbon fiber sleeves
* 4 year warranty
To add the Carbon option check the box show below on our website:
Ford Bronco REDLINE TUNING Hoodshocks carbon-
Ford Bronco REDLINE TUNING Hoodshocks bronco-maxlift-elite-
QuickLIFT ELITE features:
* 316L Stainless Steel gas springs
* 5 year warranty
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11040-03.htm
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11039-03.htm
Free shipping in the CON. U.S. on all Bronco systems using coupon code "Bronco6G" at checkout.
You can watch the video below to see how easy our installation is, the only tool required is a 13mm socket:
Here is a video of the different gas spring finishes and the system in action:
Redline Tuning has been developing our Hood QuickLIFT systems for over 20 years and have applications for over 350 unique vehicles, check out our website for your vehicle application.
Please contact us for any questions.
