Replacing factory bumper with modular bumper
TxMike
Miguel
Ford Bronco
Just received plastic covers for tow hook area. Took about 3-4 months. I don’t know about the zroad lights being upside down. I saw a video of another manufacturer that u did have the ability to flip the lenses so it reads correctly. The guys that did all the work on the modular bumper was Bronco Outfitters from Houston. Reach out to them if you have questions. It was a very long and complicated process trying to get everything from Ford. it was more waiting on part availability.
If you have questions, reach out to Arnie at bronco outfitters at 713-253-0349. I believe they are also sponsors of bronco6g.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
I was missing over 25 parts and cost was over $1,000.
Don't suppose you and Arnie documented the part numbers list needed for the complete swap? I'm in the same boat, regretting not optioning the mod bumper.
Thankfully I'm only a few miles up the road from Bronco Outfitters
Bdockins
Ben
Ga
1990 F150
Besides the tow hook brackets, what could all these parts be??
Thanks
Usdmmark
New Port Richey, Florida
GMC Canyon
Thanks
i know i'm missing the tow hook covers and it looks like there is 2 bolts per cover and 5-6 clips behind so i could be missing 18 pieces in just that small area.
Landobando
Boise
Bronco Outer Banks
Went to install the mod bumper today. My original plastic bumper has the sensors and it doesn’t appear to line up with the mod bumper. The tabs don’t line up with the mounts so it won’t mount in. Any advice?
Tylercrws
Tyler
Columbia TN
2022 Bronco
Ok….so I’ve read through all this and am not sure I understand.
I have a (what I think is) Complete modular bumper with wench bracket, bought that is close enough to go look at.
I am replacing a stock plastic bumper on a 22 base.
1) what will I need to do to swap?
2) Will the wench plate detach?
Usdmmark
GMC Canyon
You’ll need modular bumper mounts which hold the bottom of the inter cooler in place. Or you’ll have to cut the tow hooks of your existing ones. Only thing I changed to put the mod bumper on.
Gil Carolina
Gil
Charlotte
Quick question. I have a 22 Big Bend and just put R/C shackle mounts on. This required removing tow hooks. All that being said doesn’t the base/big bend share the same bumper? If so no cutting was required for mine.
Clint Callahan
Clint
Tennessee
2013 Toyota Tundra Rock Warrior Edition
In the process of doing exactly that now. Turns out I didn’t get all the parts. it has turned in to a big exercise. Luckily, Arnie at Bronco outfitters found everything I needed. A lot of the parts are on back order but they are getting there.
By the way, two completely different bumpers. Make sure you get everything you need. The hardest part to find and we are still waiting if for the plastic covers that surround the recovery hooks.
Following. How would you feel about listing the parts needed to do the swap? If you have them that is
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
DD214
Western Mass
2018 JLU Sahara, 2015 Pilot, 2022 Bronco
same. Also, you will probably need help holding the KD bumper in place as it is heavy. The bolts that hold on your current bumper will be used to hold on the mod bumper.
Finally, if you have parking sensors, you will need to trim the sensor cups a bit to get them to fit on the Mod bumper. The sensors will work fine., but not the cups without trimming.
Blaine23
Blaine
St Louis, MO
Jeep JKU
I was lucky enough to find a MOD bumper for sale on the forum to replace my standard bumper. I haven't installed it yet - but I'll need to drill out holes for the parking sensors. Has anyone done this yet or know how big the holes should be to accommodate the standard bumper sensors?
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Will find out soon enough, I had to order the sensor grommets (M2DZ-15A862-MA through -MD) since the previous owner retained his to put on his new bumper. Hopefully have everything in hand before this weekend.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Is it a difference in diameter of the part that goes through the grommet, or is it behind at the clip interface?
DD214
Western Mass
Sorry for the delay
so the sensor is the same. So the part that goes into the sensor cup is the same. The sensor cups that hold the sensor to the bumpers is different depending on the bumper.
