Retrofit installing 360 cameras after vehicle purchase (BASE)
Bronc-itis
E
South Florida
Q50 (bronco soon)
Considering how much is involved, I’m sure it would be super expensive to add 360 cameras and 12” screen.
I know I could have bought a higher trim level to get those options. But 2.7 and SAS were must haves for my base model.
typically a base with this configuration would be out of my price range. But the killer used car market and the extra time to squirrel away down payment money has made it possible. I say that to put it in perspective.
Jumping up from a base to BB is an extra 6k (before taxes🤦🏻‍♂️).
Just trying to wrap my head around the topic. 360 cameras would sure be nice in my tight ass garage.
Drex
Jake
The parts alone would be more I am sure (at list price), the labor would be substantial and you not get the extras also included
Bronc-itis
Bronc-itis
E
South Florida
Q50 (bronco soon)
how about just adding a front camera .Would tha tbe easy or real hard job/
A front and rear camera would be nice. But I’m more interested in the 360 camera for getting in and out of my garage.
Bronc-itis
Bronc-itis
E
South Florida
Q50 (bronco soon)
Who knows.. would be nice if the harness had everything included. Swap out screen and add cameras and necessary trim pieces.
KickAssBronco21
Guy
Tyrone, NM
Ford F150
If you have only the rear view camera can you switch to the 360 degree camera after the fact?
PWillette
Parrie
Maine
Are you talking changing your order or adding after you take ownership? The 360deg camera is actually multiple cameras not just one.
MadMan4BamaNATL
Ray
Atlanta
Not sure if the 360 camera array is available on the Big Bend, so you may want to look into moving to a higher level package.
Retrofitting this system would be very expensive if even possible. I say that because it would require different side mirrors since cameras are in those and different bumpers and extra wiring. These cameras are also part of a system that may be different for those models and trims that use it and built in from the factory.
Regardless if any of the above isn't 100% accurate, net, net is there are several different parts and control modules needed, even if some just plug right in, so for a seamless process, it's cheaper and likely will work better just to get the 360 set up at time of purchase.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Anything is possible, but if my experience is any indication, I would *not* consider adding the functionality after the fact a viable option.
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
This is one of those projects that's only financially feasible if you can score all the components needed at junkyard prices.
