Is there a way to connect them to a switch to disable them in case you don't have the clearance for them to deploy?
Cool, one down 2 to go!!!It comes with a switch to do exactly this
Not ideal for jacking but it's a good flat surface if you absolutely cannot get to frame or alternate spot.Incredible response from @Doetsch Off-Road !!! Couple of questions that others may be interested in as well...
Can they be used as jacking points in case of a flat?
Is there a special on the additional coverage? Powder coat does not last long in snow country when beaten up by road salt.
Thanks!!!
Door delete kits are needed in Bronco too if you pull doors off. 39.99 per pairI am told the Jeep versions require a door delete add on. This is the switch that deactivates the the door magnets when the doors are off. Does it come standard on the Bronco versions? Is it included in this deal?
order thru you?Door delete kits are needed in Bronco too if you pull doors off. 39.99 per pair
I’m in x2 ….. both 4dr ….maybe add an additional 2drOriginally posted on FB Group Bronco6x, I have started the pre-sale/group buy for 2door and 4door Rockslide Engineering Steps.
**Rockslide Engineering - GROUP BUY!**
**2 dr & 4dr models available. MUST MESSAGE ME FOR PRICING.**
***I cannot post sale pricing here.***
**This is a PRE-SALE. The steps will take 4-6 weeks to ship**
heres a video of what they do.. https://www.youtube.com/watch?v=AvJK3IjIgVQ
If you are in, reply to this post and also private message me. Thank you! We are already at 14 sets ordered on FB.
