Roof rack weight limit? Is this bad?
broncoSJ
NJ
2021 Ranger
My Mini Cooper S roof rack hold up to 165lbs. Maybe it has to do with the rack being connected to the top of the windshield frame.
DrewBronc21
New York
Apparently you can’t get the roof rack with a 4 door on 35s so no 4 door squatch with roof rack. My STi roof rack good for 150 lbs!
Ford Bronco Roof rack weight limit? Is this bad? 9E05D6B1-8AED-441C-807D-A35D896AB9A7
beachman101
;pkl
why would tires interfere with the roof rack?
WuNgUn
Ontario Canada
2 door Squatched
Are you planning on being on being on the roof while your car is driving down the highway? It’s probably rated that to prevent rollover.
That's EXACTLY why it's rated like that, and why the Squatch isn't available with rails.
level3looper
New York
With all the accessories expected, I'm hoping there's a good solution for two Hobie kayaks at 80lbs each.
MadMan4BamaNATL
Ray
Atlanta
Although I plan on using my ground tent, I was also disappointed at the dynamic 110 lb limit. Most rooftop tents can weigh around that much, some even more.
Think clamshell tents are lighter, but also can be expensive. Wonder if aftermarket solutions can help with this without being unattractive?
Do you guys think this is due to the roof panels being removable? if so, guess I can live with the trade.
elmystico
Jon
New Mexico
2014 FJ Cruiser, 1990 Toyota pickup, 2021 Audi Q8
FJ Cruiser limit is 165 lbs., for comparison. Bronco's lack of a center roof support crossbar may be part of its limits.
jaruss01
NJ
You think a medium sized packed Thule is above 110 lbs?
I’ve never put anything on a roof before, but plan to do so with the bronco
Mario3241
Mario
Las Vegas
Ford Focus
Rangerz520
Pittsburg TX
Supercharged 2019 F150 Reg Cab
Hopefully the aftermarket providers will help this. I do see attachment points at the door mirror area. So im hoping for a full size rack like a Rover.
beachman101
;pkl
From the interactive accessories thread, id imagine a rack like this would up the poundage substantially wouldnt it?
If not, then look at it like a good reason to lose some weight ?
was literally just looking for this
You think you can slide the rear roof part out from under that?
OBXdreamin
Rob
Tacoma
Depends on how the rear braces are routed: outside like the front (notice it blocks the tailight) - maybe
Rear of the vehicle - dont think so
