Running boards recommendations for 4-door Bronco?
DillyCrack
Dylan
Philadelphia
2021 Base Bronco
Has anyone with a 4 door purchased running boards yet. Have been thinking about power running boards and was wondering if anyone had any recommendations?
*I couldn’t find other threads until 10 seconds after i posted this*
DETT
Literally just installed these this evening.
Go Rhino Dominator D1 from @Stage 3 Motorsports
Ford Bronco Running boards recommendations for 4-door Bronco? PXL_20210809_012926179
Install sucks to do alone so make sure you find a YouTube video that goes over the process.
STLRFAN
Lexington NC
72 Bronco 74 Bronco 2021 Bronco
i got the factory running boards on our 4 door big bend.
I think they look great and set off the side of the Bronco. you cant do mud flaps on the front if you do running boards.
Couple posts I have seen is that the lower body trim above where the step rail is is not painted. Mine is painted body color so not sure where this comment is coming from.
Only issue I have is that water and sand pool up on them. Be nice if they had a small drain hole or something
Might be able to see the running boards in this picture. If not I can get a better picture and post later
DillyCrack
DillyCrack
Dylan
Philadelphia
2021 Base Bronco
Ford Bronco Running boards recommendations for 4-door Bronco? Bronco 3
Those look sharp I’ll have to check them out!
Cased
middle
dune buggy
Got a set of these D1 's headed my way too .
Looking good
Desert_6G
Phoenix, AZ
Ranger
I plan to get either the ones RTR has or Go Rhino's RB20
Theherofails
Thomas
Phoenix
I did an 8 out of 10 trail today and my ##^%# steps caught on every rock in sight (Ranger Tremor). If you’re gonna go off-road, get the steps that tuck in or at least sit even with the vehicle body/slider.
Seriously. I only lose 1-2” of clearance with the steps and they are TERRIBLE. Don’t do it. If you do, just take your skids plates off and chuck em right in the fuckit bucket because you won’t need em with your steps grabbing everything first.
AZshot
Desert Southwest
Vintage Motorcycles, F-150, various other
That's why I'm looking at the DSS ones, they don't go as low.
acnp2022
CT
ford
I have the GoRhino one's too. They stick out just far enough and don't drop lower like the one above
Ford Bronco Running boards recommendations for 4-door Bronco? 11
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Are those the Extreme DS? What do you think of them acting as a step?
acnp2022
CT
ford
yea they are the DS. They act perfectly fine as a step. I didn't want something that sticks out super far, but far enough to catch someones door if they open their door into my bronco. I think the one's that stick out far look obnoxious sometimes so these were perfect. I just use the grab handle and step on the steps. My gf is 5'2" and is happy I installed them.
JediMcMuffin
Tommy
2021 Bronco Badlands
Thanks for the feedback on the step height. I really don't want to compromise my ground clearance too much. I'm probably going for the Extreme DSS
NC_Pinz
Central NC
Can you give us some more shots of the Bronco with step? I'd like to see how it looks with the overall...I like what I'm seeing so far. Thanks.
NC_Pinz
Central NC
I like it. Considering the DS or the DSS. Those fit the bill.
