Swap Raptor IPC gauge cluster into a Badlands?
bosko23
Blake
Evansville
Bronco Bad Lands
See part number for raptor cluster is (N2DZ-10849-A)
Has anyone tried it? Like like other ford models mustang, F150 and maverick can plug/play.
Could someone help me out with a video to take apart dash and I'd try it out unless it would mess something up if it didn't work and not swap back to original one.
Any thoughts?
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
Any thoughts?
It wouldn’t be plug and play. There would be some amount of programming involved at least.
Ducati1098
Workshop Manual
menu
413-01 Instrumentation, Message Center and Warning Chimes
2022 - 2023 Bronco
Removal and Installation
Procedure revision date: 04/23/2021
Instrument Panel Cluster (IPC)
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. NOTE: If installing a new module, it is necessary to upload the module configuration information to the scan tool prior to removing the module. This information must be downloaded into the new module after installation.
    Using a diagnostic scan tool, begin the PMIprocess for the IPC following the on-screen instructions. Record the odometer value from the original IPC. If the odometer value cannot be obtained from the IPC (display failure), perform the diagnostic routine. If the value cannot be obtained after the diagnostic routine, the customer should supply the approximate odometer value.
  1. Depower the SRS.
    Refer to: Supplemental Restraint System (SRS) Depowering (501-20B Supplemental Restraint System, General Procedures).
  1. Release the clips and remove the lower instrument trim panel.
    Use the General Equipment: Interior Trim Remover
  1. Release the clips and position the lower steering column closeout panel down.
  1. Remove the glove box.
    Refer to: Glove Compartment (501-12 Instrument Panel and Console, Removal and Installation).
  1. If equipped.
    Remove the screws and the console handle.
    Torque: 48 lb.in (5.4 Nm)
  1. Remove the screws, release the clips and position the lower center instrument panel trim panel.
  1. Disconnect the electrical connectors and remove the lower center instrument panel trim panel.
  1. On both sides.
    Remove the screws, release the clips and remove the assist handle.
    Torque: 80 lb.in (9 Nm)
  1. Position the bolt covers.
  1. Remove the bolts.
    Torque: 22 lb.in (2.5 Nm)
  1. Release the clips and remove the lower instrument panel trim panel.
    • Disconnect the electrical connector.
  1. On both sides.
    Release the clips and remove the instrument panel speaker grille.
  1. On both sides.
    Remove the bolt.
  1. Position the instrument panel switch pack up, disconnect the electrical connector and remove the switch pack.
  1. Remove the screw.
  1. Position the screw covers.
  1. Remove the screws.
  1. Release the clips and remove the upper instrument trim panel.
  1. Remove the upper passenger side air bag bracket bolts.
    Torque: 93 lb.in (10.5 Nm)
  1. Disconnect the electrical connector and remove the lower passenger side air bag bracket bolts.
  1. Remove the RH center instrument trim panel upper screws.
  1. Remove the RH center instrument trim panel lower screws.
  1. Remove the RH center instrument trim panel side screw.
  1. Release the clips and remove the RH center instrument trim panel and passenger side air bag as an assembly.
  1. Release the clips and remove the LH veneer trim panel.
  1. Remove the bolts, release the clips and remove IPC trim panel.
  1. Disconnect the electrical connector and remove the IPC.
Installation
  1. To install, reverse the removal procedure.
  1. NOTE: This step is only necessary when installing a new component.
    Using a diagnostic scan tool, complete the PMIprocess for the IPC following the on-screen instructions.
  1. Using a diagnostic scan tool, complete the FDRSModule Configuration process for the new IPCfollowing the on-screen instructions.
Page
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Is been discussed, but I don't think anyone has done it yet.
bosko23
Blake
Evansville
Bronco Bad Lands
I'll need to get Forscan again with a windows laptop. I swaped F150 sync head unit when android auto came out. Probably similar. Still looking for a video to follow.
MrGreen55
Kyle
Oregon
toyota scion xb
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
Any progress? It would be awesome to know if this is doable
