- LUKE
- Oct 24, 2021
- 19
- 270
- 570
- Blythewood, SC
- 2023 Bronco
- Badlands
Have you tried draining the winter air out of the Ko2s and putting in summer air?
Yes, expired out dated air is of poor quality and must be transfused for new air..Have you tried draining the winter air out of the Ko2s and putting in summer air?
Toyo what? Currently looking for new tires for my F150. Which Toyo are you experienced with? ThanksI like the Ko2s a lot, but will prob go Toyo when they need to be replaced though
There’s your problem. Lower the tire pressure.what psi do you recommend? 32? 35? They are at 40 now
Good move bfgs suck so bad they never do anything well and horrible at everything.Coming back to this thread.. I put 15k on the KO2s and I've put the Goodyears back on.
The ride quality is back to OEM levels, there is definitely a different noise on the highway and they do make the truck feel a tad more nimble.
In terms of gravel, my plans for the upcoming summer have changed so that is less of a concern and I like the retro vibe of the sidewall design.
I have an unregistered beat up jeep for light off-roading and the bronco stays on pavement so that was never a concern. I bought the Bronco cause I wanted the manual transmission and a cool looking vehicle not for hardcore off-roading.
Its been almost a week back on the Goodyears and so far I am glad to have made the switch back. I know this is a very unpopular opinion on these forums but this is where I am.
AgreeGood move bfgs suck so bad they never do anything well and horrible at everything.
Can you explain your comment on the highway noise? Man the Goodyear's are loud IMHO, but I do suspect the suspension is tuned for their much lighter weight.Coming back to this thread.. I put 15k on the KO2s and I've put the Goodyears back on.
I swapped the Goodyears TO the KO2's on my OBX. Significantly better ride quality.Badlands non-sas
The KO2s are Load range C and 116 service descr - the same as the Goodyears.
Bumps are now transmitted to the cabin with much more umph. I’m totally bummed out. The Goodyear tread pattern scared me for interstate heavy rain driving but they were a very smooth ride.
I may swap them back or look into Toyos. What a waste of time and money.
Any similar stories?
Previous ride was a Tacoma with KO2s. They also rode harshly but I attributed that to the E sidewall rating
the suspension doesn’t carry the weight of the tires?Can you explain your comment on the highway noise? Man the Goodyear's are loud IMHO, but I do suspect the suspension is tuned for their much lighter weight.
No.the suspension doesn’t carry the weight of the tires?
did the same recently on my Wiltrak. I had BFG KO2s in the past which is why I switched to them; knowing I would get rid of the awful road noise and rock flinging from the Goodyears.I swapped the Goodyears TO the KO2's on my OBX. Significantly better ride quality.
no. wheels, tires, axles...unsprung weight.the suspension doesn’t carry the weight of the tires?
No, the suspension carries the car.the suspension doesn’t carry the weight of the tires?
