There is also a procedure in the manual... my problem with both is the part in this pdf as steps 3 and 4. I can't believe pulling where indicated won't break the piece. The fasteners look to be one way as in they spread out and have to be squeezed from the back. I just did this and was really struggling until I found the video that shows pulling the quarter panel side away and the lamp/trim all coming off together. The video way was successful for me.For those that need written material.
They’re stronger than you think. I wired mine for flat towing and pulled both sides with no issue whatsoever.There is also a procedure in the manual... my problem with both is the part in this pdf as steps 3 and 4. I can't believe pulling where indicated won't break the piece. The fasteners look to be one way as in they spread out and have to be squeezed from the back. I just did this and was really struggling until I found the video that shows pulling the quarter panel side away and the lamp/trim all coming off together. The video way was successful for me.
I would love to see a video demo of this procedure or the one in the manual to help me understand... maybe these panels are tougher than I think but I didn't want to find out with my Antimatter Blue one.
Thank you! I plan on putting LEDs into my BD.... And then hopefully never have to go in there again..Found this video and this worked for me. Haven't seen much posted on this, just sharing!
