The million dollar mudflap fix (for Squatch rock fling)
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
Looks like WeatherTech has them now. I called as well, spoke with a representative, to confirm fitment with rock rails and sasquatch. The photo is a "stock" photo however and does not show a front flap or a front flap mounted on a Bronco. I rolled the dice, given the representative said these are correct for Sasquatch w/ rail. We'll see what arrives.
I ordered a sas set(wildtrak they call it). We'll see....
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
  • Like
Reactions: RLW
mrdibbles
St. Augustine, FL
2021 Bronco Badlands - SAS w/ LUX Package
I'm not sure you should select Wildtrak unless that's your model. The next question in the fitment matrix is 315 tire or standard. I take the 315 tire to mean Sasquatch. Given I have Badlands w/ Sas + rock rail that is the front set I ordered.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
I'll never own another set of BFGs. My last set literally came apart due to belt separation. All 4 of them!!!
Lol. How far were you airing down?? Weight of truck/payload?
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
No airing down at all and no load in the truck.
The tires capacity was well beyond the SportTrak which never had anything beyond 200lb in the bed or ever used to pull a trailer.
Simply badly built tires.
I've learned my lesson about BFG.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
I'll mention this again as it seems to have gone unnoticed. The mudflats don't do much to prevent rocks from flinging on these rigs. I installed a set as you can see in my avatar and I still ended up with rocks inside the coach of the rig while driving the one gravel road I've driven on since I took possession of her. Fortunately I had no doors on it and the rocks went inside instead of on the doors.
It's a waste of time and looks horrible to boot.
My flaps work really well. I modded the Ford ones.
pfbz
CO
F150 Turbo, 991 Turbo S, 996 turbo, Q5 Turbo
It looks like the front mudflaps are the same part number if you choose Wildtrak or non-Wildtrak with 315 width tires, part #110140.
If you choose Wildtrak, it also shows rear flaps as available, part #120140, but that option doesn't show up if you choose non-Wildtrak with 315 width. Possibly a steel vs. plastic rear bumper issue?
As noted previously, they currently have no options for non-Sas.
buzpro
Binky
Tacoma
I have been thinking about this exact same thing. My idea is to slide over the end of the rail like a boot with flap. Here is a photo of a test idea. I think 3d printing something like this would be great! Thoughts?
you stole my idea!!! LOL .... I think the slide on piece should be some sort of metal ( maybe Aluminum) and gets pinned or bolted to the rail .... the top portion needs to be secured to the inner fender somehow .... think about wind resistance doing 80 mph !
on the other hand I'm concerned about any type of mud flap binding up when you go over stuff off-road
I really like how short they are on the Raptor
Ford Bronco The million dollar mudflap fix (for Squatch rock fling) 1645114737844
mi dos centos
Biltwild
New York
2014 Nissan Titan Pro-4x , 2021 Ford Bronco 4Dr BD
mi dos centos
Haha been thinking about this since I got my bronco in July. Took in my own hands to get something out there. It’s also nice to have some different options. I have prototypes made and now just doing some material testing.
with any product it’ll only get better once people are using them and we get more feed back. Should have specs and preorder info next week. No drill , no modifications at all. We want it to easy peasy to put on and off as needed. I will do a separate thread when ready.
buzpro
Binky
Tacoma
Sounds like you're pretty far in the thought process ... cant wait to see the end result. Now if you could only come up with something for the running boards ... kidding of course
Just one thing though: If you go with 3D printing make sure the material is pliable to some degree .... printed material that I'm aware of are more on the brittle side and get marred easily
Also when you start the new thread please link it here .... cuz most of us are watching this one
Tilzbow
NV
GM Sierra Diesel Pick Up
Stock goodyear Territory's? They excel at grabbing those little pebbles. I went BFG KO2, but they haven't balanced well (have already warranteed 3 out of service for being square). They did reduce the small gravel flinging by a massive amount. I hear good things about Ridge Grapplers too.
Wow! Not balancing was a widely known problem for KO2s 15 - 20 years ago. That and the fact I shredded the tread and sidewalls on a set after one hunting trip in the typical sharp rocks in the Nevada desert mountains about 20 years ago is the reason I, and many friends, switched to Toyo or Nitto AT tires years ago. I kind of figured they’d gotten a handle on the balancing issue since then.
shimmy825
James
Los Angeles
2017 Mazda CX-5
Following - please keep us updated.
We_Love_Tacos
www.bronco6g.com
One would assume with the WeatherTech mats that Wildtrak was mistaken for Sasquatch?
Biltwild
New York
Yeah side steps are another animal. Haha but definitely a thought.
One problem at a time.
Will do! You guys are my market right here! Ha
3D printing was only for prototyping purposes. Production pieces will be molded from high impact resistant urethane. We may add fiber glass chop to increase strength if needed. Can’t wait to show you guys what I have been cooking up! I even gave them a proper name! stay tuned 🙃
