Tibus Portals, you probably want to be very careful on the installation.
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Without trying to speak on which portal is better then the other. I will say I watched an entire install of the Bronco Tibus portals and a lot of what this guy is talking about didn’t seem to be a thing for the new Tibus portals. In fact, it all seemed very easy and quick, everything was very well designed and fit together without any crazy pressing except for an axle fitting. @Snacktime was there too and has more experience in these matters so I’d like to hear what he has to say.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
The issues in that video do not exist on the current design. Tone rings are pressed on with no alignment pins. The bracket that caused the damage is now adjustable. Wasn't bolted up in my picture.
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. PXL_20230901_165608364
The other big item was the bolts went through the portal making it very hard to install, now they thread in from the back. I would personally like to see a threaded insert but that is my engineering background.
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. PXL_20230901_164626382
I think just about anyone could install these if you can use a torque wrench. Now changing the bearings I would relate more to setting up a ring and pinion. The skill to pull steel bearings out of a aluminum housing is a challenge.
I do not see any big red flags with the design. Getting parts could be an issue, but don't really see anyone trying to fix a portal. If you kill a gear/bearing you might as well just order another portal assembly. It's like a rear end, destroy one gear/bearing you just change everything.
5GENIDN
5GENIDN
Joe
Idaho
Even with a new design.... And lets call it out... those were portals designed for a g wagon not a bronco... BUT... When using helical gear sets and the appropriate bearings they have to be preloaded correctly. And remember there is more than two companies offering portals for the bronco.
popo_patty
Caleb
Sacramento
I wanna hear about werewolf. Where is their stuff
5GENIDN
5GENIDN
Joe
Idaho
Now that is fascinatingly I actually thought the tibus were cast ferric.... You are saying the housing is aluminum... I would love to get my hand on them and see them in person. I do worry about the amount of axial loading that housing is going to have to resist.
popo_patty
Caleb
Sacramento
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. 366358DE-3FB3-43EE-89AB-CC2376D1A8DE
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. BB69F885-6517-42D2-97C5-D71F64325EC9
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. DECF4885-5ED9-4E30-B264-C8C075B24D1A
5GENIDN
5GENIDN
Joe
Idaho
Still not liking the bearing sets from the idler down... There is axial loading on those.... I do not see where it is being accounted for.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Germans got that solved pretty easy, this dish threads in. To set the preload and take play.
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. PXL_20230901_164824315
The square cover with pins then goes on locking in the preload. Same thing as a nut and cotter pin on trailer axle.
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. PXL_20230901_185459589
There are plenty of things to go wrong but overall it's a simple design. I do not see to buch of an issue with the helical cut gears. The pitch on the teeth is really mild, cough sales gimmick lol.
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. PXL_20230901_165815937
I would say the portals where pretty molested prior to install. Really different when you put your hands on them. The only concern I have is the wheel hub. Having had lots lifted trucks the wheel hub takes a beating and I am not sure how long they will last big tires. This is no different from my bronco as I am running 37s on a factory hub.
5GENIDN
5GENIDN
Joe
Idaho
Maybe I am worrying about things that will never come to pass... Maybe it is fine.... but it still worries me.
5GENIDN
5GENIDN
Joe
Idaho
good point on the hub... a concern for all of them.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Same boat, that is why I let other people buy them. If you really are looking to buy, I would be more worried about the stock axles and steering. Big tires + Portals is a lot of rotational mass!
5GENIDN
5GENIDN
Joe
Idaho
I am very aware of the rotational mass differential. As well as the additional unsprung weight inertia that will need to be overcome (at least at speed). I used to teach people how to do those calculations. And yes the steering needs addressed. That cast alum housing is a weak point. I do not like the idea of upgrading tie rods until that is addressed. I see tie rods as a fuse. I don't want to put a bigger fuse in the circuit unless the line has been upgraded to handle the additional load.
builtMIbronco
Zach
Hillsdale Michigan
22 Black Diamond on 37s
Ford Bronco Tibus Portals, you probably want to be very careful on the installation. IMG_5360
I'm assuming the housing is what's cracked, but not sure we will ever hear more about it. The housings are 7075 aren't they?
