- Aug 3, 2021
- 3
- 104
- 274
- California
- Subaru
- Base
So, i've been researching this topic as much as I can over the last few weeks/months trying to come to some firm answers but I am having difficulties in that. I thought I would post a topic relating directly to tire size and what the effects can be based on the size. LEt me expand upon this slightly related to the questions I am having.
I like many other people on this forum want to get bigger tires for my vehicle. The question I am having is what will the negative affects of this be on the wear and tear for my vehicle and what size can I reasonably get and avoid this fate. I am not really concerned with the louder driving noise, slower braking, worse handling. I am more concerned with the wear and tear aspects of the larger tires.
I have a base non-squatch on order and would like to updgrade to a size 33 tire but would this tires size and weight work with the components of the base. The base gearing is only 3.73. Is that gearing enough to handle that tire size without causing early failure of components? Would the gearing not need to be more like 4.10 to avoid early failure? Also, the heavier weight of the larger tires. The bigger tires are substantially heavier. Would this extra rotating weight cause failure of components as well. I assume with bigger heavier tires the axle, ball bearings, and transmission would all be put under stress they werent designed for. Is this line of though correct with 33in tires? There seems to be alot of conflicting information out there regarding this. I am sure alot of it is peoples bias trying to justify there actions and this is why it is hard to wade through fact from fiction related to this.
What I have determined as it relates to larger tires on a base is a size 32in is probably acceptable as the outer banks has the same size tire and same gearing and axles. I am not sure how much tire weight matters but I assume you would want to stick to around a 40lb tire like the outer banks has.
If anyone can help expand on this and give some advice that would be very helpful to me and I am sure others who are trying to figure this out would be appreciative also.
