Tire size question for the OBX community (Toyo vs General vs Falken)
Broncomike11
Ford Bronco
I've posted quite a bit on tires and hopefully this is the last before I make a purchasing decision, but I think I'm about at the decision point. However, I wanted to question the OBX community on tire size, based on their current setups. I'm riding a non-sas OBX, and am between three final tire selections to purchase:
  • 275/65/18 Toyo AT3 (C Load)
  • 285/65/18 Falken Wildpeaks (SL Load)
  • 275/70/18 General Grabber ATX (SL Load)
Ultimately, I'm looking to choose a tire that (1) fills out the tire well noticeably better than the stock Duelers, and (2) is somewhat durable for occasional off-road driving in Colorado. To specify, I don't do any serious crawling or off-roading - I've been using SL tires for the past 2 years. I prefer the the C load more for peace of mind depending where I'm at.
While I'm leaning towards the Toyos, my biggest concern is that the 275/65 might still appear small on the OBX even with a more aggressive sidewall/tread pattern. Similarly, I've seen some posts on the forum that the 285/65 might look a little funky without a level/lift for my Bronco. Does anyone have experience testing out these tire sizes on their non-Sas Bronco?
Though I understand 275/70/18 is by far the most popular way to go - my hesitation is just that the Grabbers are personally my least favorite (at least aesthetically) of the 3 tires above...
Thanks in advance for any insight/advice.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
The Grabbers (albeit in 265/70-17 for me) are the best non-dedicated winter tires I have ever driven in the winter, even better than a set of Hankook iPike's I used to have on my Xterra. Not as good as Blizzaks or Hakkapeliittas, but good enough I will run them one more winter (I have 285/70-17 MT's for the summer now.) Good on the highway, good on the trail, and good in the wet as well.
JohnnyBronco
Pennsylania
X4
I have no problem with the oem size 255/70 18 filling put the wheel well.
Two optional tires for you to consider, while I have had decent experience with the Generals, I have had better results with Continentals. Terrain Contact A/T compares favorably with the Grabbers (according to tirerack.com) But a real contender is Cooper Discover Road +Trail AT which at higher load and speed ratings.
If you have a local shop that sells Msstercraft their tires are well performing g less expensive alternatives.
Caveat: both Cooper and Mastercraft are currently Goodyear brands but operate independently
Dan-O
Dan
Fountain Hills, AZ
2021 Bronco Outer Banks
I’m running 275/65r18 Toyo AT3 on non sas OBX. No tread noise, wider tire looks proportional to wheel wells. My decision to go with this size was to keep weight closer to stock and so speedometer stays same. Tire poke is still inside flares.
cape2267
Nova Scotia
F150 supercrew FX4
Hi, although not listed in your final 3, a few weeks ago I went with Cooper Rugged Trek on non-sas OBX - 275 65 18 - and they are great. They measure out at 32.5 inches so are slightly bigger than stock but not quite 33's. there is no road noise to speak of (at least not that can be heard over the wind noise from the top) and have an aggressive and deep (16/32) tread pattern. They are P rated but I only do mild off-roading such as fire roads to some fishing spots etc so will serve me fine. Shop said they were very easy to balance and hardly required any weights at all. They replaced Cooper AT34S which were also a good tire but not as aggressive a tread pattern as the Rugged Trek. I can provide pics if interested.
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Non SAS OBX 26570R18 Falken Wildpeak. Went with a Raceline Wheel pushed the tire out 18mm from the stock offset and made for a more aggressive look. I changed flares for the winter and will put the stock ones back on soon. Double check before you go with a 285 on stock wheels to make sure you have clearance with suspension travel especially on a lock to lock turn.
Rob_Broncowski
MA
'22 OBX, Ducati Scrambler
Not the best images due to the poor weather today but this should give you an idea of what the Grabbers look like on an OBX with stock wheels and suspension.
