After about 1.5 years of driving with the stock tires on my non-sas OBX, I'm finally deciding to upgrade my tires ahead of the Colorado Winter.
Currently I'm looking to upgrade to 275/70/18 tires as to avoid the cost/hassle of replacing the stock 18 inch rims (I really wish OBX had 17...). Due to the smaller available inventory for 18 inch rims, I was curious if anyone here has had any experience/thoughts on the following items:
-Load Range: I see most tires at 275/70/18 have a load range of E. Though I'm in Colorado, most of my off-roading involves gravel paths and more open fields for camping, as opposed to true crawling or more involved off-roading activities. Based on what I've seen I feel C makes the most sense, but due to limited options I plan to stick with SL for the General Grabber AT/X. Has anyone had problems using SL tires for relatively limited off-road use?
-Size: I decided on 275/70/18 after reading through many posters on the board. However, I just saw a post on here with someone who successfully installed 295/70/18 on a non-sas OBX. If I plan to still use my Bronco for limited off-roading (and will be driving on ice/snow for 5-6 months out of the year), would anyone here recommend I go bigger than 275?
-Offset: I embarrassingly admit I really don't know much on this topic. Anything I need to know going from 255 to 275?
Appreciate any insight you all might be able to give.
