Best advice ever!!When you hear hoofs, think horses, not zebras.
The repair records from the first couple of breakdowns:
Depends on state for the title, but the CarFax will show if it is taken as a lemon law return.Does the title reflect that the car is a lemon if you keep it? Akin to a ‘salvage’ branded title situation?
Thanks for looking at the errors. Sounds reasonable. I was driving through really intense rain before it happened the first time. Pulled over at a Cabela's to let the storm pass. When I came out, it wouldn't start. Did notice the gigantic gaps in the front wheel well linings. Seems like that could allow a good deal of water to spray up into the engine compartment.I just went into Ford PTS website and looked at your Diagnostic Trouble Code history. There are several modules that are losing communication with the PCM and there are modules that are storing battery voltage codes. Based on the dealer in Salina (Who I used to call on as a Ford FSE) saying they found water in the Battery Junction Box, I am guessing that the water caused corrosion in the BJB and that is intermittently killing power to the PCM. That would shut you down instantly and cause the other modules to lose communication with the PCM. The BJBs are not just fuse boxes any more, they have internal non serviceable relays, integrated circuits (chips), and they communicate on the module communication networks. A little water in the wrong place can cause a bunch of problems.
This isn't the 70's. You can't diagnose cars with fuel. Fire, spark. Modern cars are full of modules and computers. I had a car that modules would randomly stop working and it was because of a small crack in the tail lightSeems techs now can not use their own thought process. They are guided by fords how to fix a vehicle book. No room for deviation and if they want to they need to get an act of God to do it.
I agree with the battery issue. It really could be as simple as that.There was a post recently where multiple people had random power loss issues that traced back to a loose battery terminal connection from the factory. There's no excuse for that to have been missed several times by your dealership, but...
You may also just have a cursed battery. Apparently this can happen but be undetectable by the dealership when they check it. Want to know how I know?
Earlier this year my mustang had a 3 year + 1 month old Motorcraft brand battery in it, and it started having crank issues.
Took it to the dealership because I wanted to use the amortized warranty left on the battery to get it replaced for a discount, the damn batteries are like $200.
I ended up there multiple times over a couple weeks. At one point, they kept my car for 3 days and benched the battery, trying to find something wrong with it. NOTHING. Eventually, i needed to move on with my life so I asked them to just put a new battery in, at full cost. The car has been fine since.
There's that saying,
Your dealership may be pre-occupied looking for zebras, ask them to replace the damn battery. It's easy, and they are readily available parts.
