- Thread starter
- #1
I have a ‘21 Wildtrak with 5k on the clock. I recently noticed an odd noise at start up when the truck has been sitting for a bit. Turn volume up and let me know if anyone else has experienced this.
That was my first thought, diesel. But no, does not sound good.Did you install a diesel? JK. That doesn't sound bueno, I would check oil level asap. That is a sound rockers made back in the day when not lubricated (Low on oil). Shoot, It's under warranty, get Ford to come pick it up!
How many miles did you have on yours?Your cam phasors are toast. Dealer will have to pull the engine and swap all 4 out.
It'll slowly get worse until you have it fixed. I just went through this with a Badlands w/2.7. Took 4 days to get it back.
5500.How many miles did you have on yours?
Yes, most use a similar design. It’s been a problem for years and Ford still can’t figure it outWhy are cam phasers and issue on multiple Ford engines? Is the design shared somehow?
It’s cam phaser rattle. Unfortunately it’s common on a lot of Ford engines. The phasers will need to be replaced.
They were never an issue in my SVT Focus... 7200 rpm all day long.Yes, most use a similar design. It’s been a problem for years and Ford still can’t figure it out
