Updating Your Base with 265/75R16 Tires?
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRD
I have a base 2 dr on order so can't speak to that yet but I do have a 17' Tacoma TRD that I had 265/75/16's on for 35k then I did 285/75/16's 10k ago. The 285's ride better than the 265's but I did lose 3+ MPG as I did Toyo Muds instead of the 265 BFG's. The 285's look and perform many times better than the 265's and that is what I'm putting on our base IF we ever get it.
Oakpv1
Patrick
San Francisco
2020 AWD Ford Ecosport
Are you planning (or have you) installed 265/75R16 on your Base Base Model with stock 16x7 wheels?
I am curious about the following if you can please share (just 265/75R16 on stock 16x7):
  • Which tire brand did you install?
  • Was their any interference/rubbing?
  • How is it running with new weight/size?
Thanks in advance for your help!
Now have just over 600 miles on my Base 2 door Bronco. I upgraded the tires last week to 265 75 r16.
Which tire brand did you install? Toyo Open Country A/T III (SL load).
Was their any interference/rubbing? None whatsoever.
How is it running with new weight/size? Rides / drives just as good as the original tires.
titleistforged
Wayne
Oakland
2023 Bronco Base, 2024 IS 500
Chiming in - I also put 265/75/16 on my stock steelies. Zero issues so far. Falken Wild Peaks. Drives comfortably on the highway so far.
Dmesser92
Dylan
Easley, South Carolina
1991 Toyota Pickup 4x4 DLX
Ford Bronco Updating Your Base with 265/75R16 Tires? 9E73C4DD-D49D-4BA2-81A2-25EA779CE98F
Finally a Base Four Door with 265/75s, thanks for posting!
titleistforged
Wayne
Oakland
GPPBronco
Detroit
2019 Ford Transit Connect; 1997 Jeep Wrangler
BFG KO2 285/75/16 on base with stock wheels. I’ve only ran them a couple days, but I did make a 50 minute trip (one way) on them, which is likely longest I’ll really ever make. Maybe they aren’t recommended for a 7” wheel, but they seem fine so far.
Do you have additional photos? Interested in KO2's in this size and wondering how wide they look from the front/rear. My preference is for 255/85r16 but the tread options are very limited.
Future_Bronco
Paul
2010 Hyundai Elantra GLS
Here's some additional photos with different angles... the new 265 75 r16 tires are right at the edge of the fender flares.
Thanks for the inspiration! I am definitely getting these tires when I get my base.
Hey Buddy
Drew
2022 Ford Bronco Base Model 2-Door 2.3L 7-Speed
Ford Bronco Updating Your Base with 265/75R16 Tires? 679858001
Here is my 2022 with 265/75R16E BFG K02s on factory 16"/7" steelies! Drives great & am getting about 16/17 City & 18/20 Highway.
Feeleyman_
K.C.
2019 WRX
what kind of MPGs are you getting with these 265s?
Clarke
Canada
2022 Base Bronco
These look like 285/75R16. Are you sure these are 265?
KimDracula
LJ
Easton
Jeep CJ
Didn’t see this question asked, but is your level lift Just an inch in the front? There’s no lift in the rear at all, correct? Thanks
GPPBronco
Detroit
Inspired by @Oakpv1 I ordered a set of 265/75r16 Toyo Open Country AT3 as my “winter” set of tires. There was no way the 255/85r16 Falken MTs were going to provide the winter grip needed in the Great Lakes.
So far (three days, around town only) the difference is remarkable. Much quieter, smoother. Do they look as tall/gnarly as the Falkens? Nope. But it still looks good, and I’m not trying to get the rock crawler look. I’ve always like bronco builds that are focused more on practicality. Hence the base without a lift.
Looking forward to family trips “up north” this winter. And to the local sledding hills.
Ford Bronco Updating Your Base with 265/75R16 Tires? IMG_3221
Ford Bronco Updating Your Base with 265/75R16 Tires? IMG_3226
Ford Bronco Updating Your Base with 265/75R16 Tires? IMG_3222
