Using the windshield washer at high speeds is a joke.
lilthom
Thom
Hartland, Wisconsin
2021 4dr Badlands 2017 Superduty 1973 Bronco
Anybody else experience this. A big bug hits the glass right in your line of sight so you hit the windshield washers at 70 mph. Since there is nothing aerodynamic about these Broncos, the wind bouncing off the windshield blows the washer fluid back on the hood. It's only a little mist that actually makes it to the glass. Then when it dries up the hood is all streaked from the washer fluid. I don't know that there is a fix for this unless we go to the new Heep windshield washer blades that have the squirters in the blade itself.
illverado
Cory
700whp stick shift 2000 silverado 2011 caprice ppv
Mine works perfect must be a 4 door problem
lilthom
lilthom
Thom
Hartland, Wisconsin
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
Looks like maybe the trail armor on the hood lip causes the airflow to change enough to throw off the washer fluid.
Southern Girl
1974 Bronco/2023 Bronco
You are probably out of cleaning fluid.
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
That's my experience. Washer fluid application was fine and then I put the hood deflector on. Now I don't bother above ~40 mph. Most of the fluid won't hit your windshield. :ROFLMAO: But the deflector keeps most of the bugs off the bottom 2/3 of the windshield, so that's nice.
lilthom
lilthom
Thom
Hartland, Wisconsin
I believe you guys have uncovered the cause. That deflector is staying so I suppose I will just wait until I have slowed down to use them or lean to the side to see around the bug splats. Like Mike said, it does minimize the bugs so I guess it's a wash (no pun intended).
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Nope...haven't seen this "issue" at all. I drove all the way to Colorado and back with no problems.
SavSqch
Savas
CT
2022 Wildtrak
Definitely sell it. It’s so broken and it may actually kill you while driving.
Just sell it.
Just sounds so awful.
