I would not use the pre production numbers true tow rating is TBD as noted on Ford website. They use 3500 lbs because that is the max for a Class II hitch. A Tow package will have class 3 and will raise rating with addition of transmission cooler line. The Ranger published the same figure prior to order guide and ended up being 7500 lbs.If the MAX tow rating for the Bronco is 3,500 lb as they have indicated, the Sasquatch package will certainly reduce that figure. I hope you have a light aluminum trailer!
Yea I kinda laughed at that too.....maybe just used stuff with retirement around the bendLOL, that's what I said when I was 60 and bought the Raptor then a motorcycle then a motorhome. I did sell the 4 wheelers for some reason. Mom and dad were still wheeling into their 70s.
Alright. Perhaps I should lay off on the tow rating comments until we hear more from Ford on the subject.I would not use the pre production numbers true tow rating is TBD as noted on Ford website. They use 3500 lbs because that is the max for a Class II hitch. A Tow package will have class 3 and will raise rating with addition of transmission cooler line. The Ranger published the same figure prior to order guide and ended up being 7500 lbs.
Welcome to 50.right now im in the 45 to 49 group, but that changes next week lol. Dang, im too old for a Bronco
There’s almost 200k reservations you may want one if you want anything less than a 2023 MY LOLI turn 28 in September. Haven’t reserved, yet. Planning on buying around my 29th birthday.
