What are the easiest ditch lights to install?
Nectar
Don
Bronco ordered
Are there any out there that are ready to go for connecting to the upfitter aux switches? All I've seen says they require modifications so far.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Your Aux wires have no connectors on them they are cut and sealed. There isn’t anything that’s made for that without striping the end and putting in a connector or soldering a wire to it and using shrink tube. My really cheap set came with brackets and everything. Remove the accessory bolt run wiring under cowed and put the. Our back in through the bracket and your done. Was pretty easy. I did paint the brackets black.
Ford Bronco What are the easiest ditch lights to install? C1C3326A-98AE-4F40-B39D-0F912C79284B
Ground_zero298
Scs michigan
All of them are pretty easy. 2 wire on the uplifter would be the easiest. That would just be the black to a ground bolt of the firewall and the red connected to a uplifter wire tail under the hood in the drivers back corner.
Any thing with a relay would be close to the same with one extra step. The relay wire would go to the uplifter wire, the red power would go to the battery.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
That would be either the Baja Designs or Diode Dynamics kits. SUPER easy to install. Our kits include the harnesses you need that make it REALLY easy.
Diode Dynamics SS3
https://www.4x4truckleds.com/diode-dynamics-stage-series-ss3-ditch-light-kit-for-2021-ford-bronco/
Ford Bronco What are the easiest ditch lights to install? 1666371118036
Diode Dynamics SS5
https://www.4x4truckleds.com/diode-dynamics-stage-series-ss5-ditch-light-kit-for-2021-ford-bronco/
Ford Bronco What are the easiest ditch lights to install? 1666371133641
Baja Designs
https://www.4x4truckleds.com/baja-designs-a-pillar-kit-for-2021-ford-bronco/
Ford Bronco What are the easiest ditch lights to install? 1666371147875
We've got plenty in stock.
Nectar
Don
Bronco ordered
Diode Dynamics SS3
Diode Dynamics SS5
Baja Designs
These look great!
Cactusjk
Scottsdale, AZ
2023 BL 2 Door, 2007 FJC
Any 2023 Black Friday ditch light deals
4x4TruckLEDs.com
Adam
Lindenhurst, NY
CUPRA
Jared
'21 Bronco OBXSAS/'23 Camaro SS Convertible
Here’s my install video for the Ford Performance ditch lights, hooked up to the AUX switches. Very straight forward!
Cactusjk
Scottsdale, AZ
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Now which ones to get? Open for suggestions. Prefer combo for overall visibility.
Combos are the most popular of course.
SS5 is what we run on our demo truck. I like the RGB as we change the color on all our SS5 to match whatever season we're in at shows. Here is a recent Halloween show for example
Ford Bronco What are the easiest ditch lights to install? Photo Oct 28 2023, 6 19 49 PM
And they are really bright. You can save money with the SS3 of course. But I like a combo. I don't do any races so I don't need that spot light to go down range. The SS5 in a Combo throws out a lot and the Driving portion of the combo is basically a wider version of a spot light. The floods light up everything else (combos = driving + flood).
I find SS5 in Combos out perform the smaller SS3 of course.
Here's a customer who went with a blue theme
Ford Bronco What are the easiest ditch lights to install? DIode2
Or SS5 across the roof and S3 on the pillars for comparison:
Ford Bronco What are the easiest ditch lights to install? 317813693_3324608414448568_1020799704027319866_n
GroovyGeek
Boyan
'23 Bronco BD
Without telling us why you need them it is impossible to tell. Mine are for very occasional non demanding use, mostly sharp turns on trails and or finding where the trail intersects the paved road. Almost any light will do for that, I went with some low profile nilight flood lights for a grand total of under $30.
All ditch lights are equally trivial to install.
Cactusjk
Scottsdale, AZ
Here in AZ just want to apply more light to the sides and maybe go with a combo lens. I like the Baja Designs if someone can point me to a reasonable ditch light for that purpose.
Looking at BD Squadron Sport or XL Sport.
CrazyPete
Buffalo, NY
2018 GMC Denali 2500HD Duramax
Definitely prefer round lights over the square ones....just looks better imo
Cactusjk
Scottsdale, AZ
I started out looking at the Ford Performance round Rigid lights and still might go that route.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We offer Diode Dynamics and Baja Designs with round bezels on request (it makes too many drop downs if we add it to the drop downs). You just have to ask and we'll swap in round bezeled lights.
