What are you plugging into the Aux switches?
rich
Rich
Los Angeles
2003 Jeep Rubicon, Moto Guzzi V7 III
blkvirus
Southern CA
'19 Rav4 Adventure, '06 Mitsubishi Evo IX SE
Light bar, fog lights, ditch lights, winch
MaverickMan
Shane
Winch in/out, front lights, under lights, 360 degree rack lighting, fridge power.
bladsquatch
Cameron
Crete, Greece
2013 F150
fridge power.
Ohhhhh I hadn’t even thought about that..... I wonder if the Aux switches will be able to be used when the vehicle is off. I was looking at power banks tied into the battery.
rich
rich
Rich
Los Angeles
jtzako
Jason
Xterra Pro4x
For me it depends on what sort of factory options there are. If there is a factory onboard air I wont need an aux switch for that (unless it uses one of the spots). Same with some lights etc. I will have onboard air no matter what though so that is one potential.
The winch? kindof similar. Is there a factory option and does it use an aux slot? I dont know but my current winch has its own power switch on its controller box so there is no need for it to be on an in-cab switch.
MaverickMan
Shane
Fridge power?? I'm interested.
Gotta put a fridge/freezer in back. Ford is supposed to have one as an addon accessory. Id like to have its power source on a toggle independent of whatever key mode the vehicle is on.
JGee
Traverse City MI
planning on using the rear quarter panel lead for an aftermarket subwoofer.
JohnnyX
Pentwater, Michigan
2008 Ford Explorer
Thinking about additional 110V output... for the rear cargo area. Need to investigate if I can order the second row power outlet as a service part and how hard it would be to install... I assume the inverter is a separate part.
jd-ford-hd
Tennessee
‘16 Explorer, ‘13 F150, ‘99 F350, '74 Bronco
Hoping you guys are just kidding about the winch.!
JohnnyBronco
Pennsylania
X4
It's okay if you use a relay, otherwise you understand the amp draw direct to the winch itself exceeds the ratings of all aux switches combined by a large enough margin to start a fire.
jd-ford-hd
Tennessee
Bad idea.! Auxiliary switches are either "off" or "on", not "momentary". Every quality winch on the market is available with wireless remote control. No brainer on this one.!
