Let's talk Aux Switches - what are your plans?
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Interesting to note, and I have no clue if its true, but my dealers Bronco expert mentioned that the first three switches are your "high amp" switches and the last 3 are low amp. He did not specify what the cut off was, but mentioned I wanted to keep high draw equipment on the first three toggles.
I will be equipping my Bronco with additional upfitter switches on top of the 6 included. They fill up quick. I will likely move all my lights over to a Switch Pro's 6/8 button panel and keep the 6 built in switches for low amp draws.
Items going on upfitters so far:
1.) I installed an RGBw lighting kit first thing. Bronco is DARK inside at night. Very bright LEDs under all the seats. Master switch to disable (maybe, on the fence on this one)
2.)ARB fridge
3.) Rewiring 12v in center console through an upfitter because it is always on.
4.)master for Switch Pros upfitter switches (if needed)
5.)Solar cut off for the panels that go on the roof to keep truck battery topped off etc while camping. The juice goes into a high capacity "power station" generator as a second power source for vehicle.
6.)GRMS radio
7.)Master toggle for 3 channel dashcam (front, back and inside)
I'm still building my lighting setup so I don't have the exact info. It will either be full Rigid with a 40" lightbar on bumper, 4 pod lights for mirror mounts for ditch lighting and their rock lights. If its Baja, its the 40" linkable bar for the bumper, ditch lights, rock lights and backup lights.
For those unfamiliar, this is a Switch Pros upfitter panel:
Not my photo, just some generic example.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Aux switches will be a TBD adventure for me. Maybe some fob lights, rear dust light, etc. I’m not a light bar guy so it all depends on how the headlamps function.
Odd coincidence…but I totaled my 85’ Bronco in 1993 while listening to Thunder Kiss. I still have the rear emblem.
Panzer948
Bryan
Charlotte, NC
1981 CJ5, 2015 BMW M4, 2019 Jeep G.C. Trailhawk
Vehicle Showcase
2.)ARB fridge
6.)GRMS radio
I've been eyeing this Switch Pro for a future build myself. If done properly, it can look very clean and I love how each can be custom labeled with pics. I actually think it looks better than Fords Aux switches (looks more factory built). Curious where you plan to mount it in the Bronco.
Theherofails
Thomas
Phoenix
2021 Audi Q7 Prestige, 2021 Bronco Badlands Sas
Im doing all self install, so over the coming weeks I'll be rolling out some small tutorials for the guys who are also too cheap to pay someone to do this stuff. Err, I mean.. handy. The guys who are handy. Thanks to another member who turned me on to the concept, I believe my switch pros will live in a 3d printed enclosure attached to the overhead switch assembly. Probably canted 30 or so degrees towards the driver instead of just parallel to the switches.
First comes a small walkthrough on in cabin lighting (its WAY too dark in the hard top at night) and then a 3 camera dash cam/security system install.
GotWake
Tony
2.)ARB fridge
6.)GRMS radio
That’s pretty slick. I have no clue. But, I feel like I’m going to go crazy adding stuff to mine.
Panzer948
Bryan
Charlotte, NC
Vehicle Showcase
Wow, overhead and tilted. I am looking forward to seeing your tutorials. Back in HS I bought a generic overhead console from JC Whitney to mount a couple of driving computers, with one that even talked to you. I become well known for all the gadgets in my car.... and this was back in the 80s. Fun to relive the fun in a new modern vehicle that is easy to modify! I may have to jump on board with some of these ideas.
OCDON
Don
Ocean City, NJ
2013 Wrangler
I agree the cabin is way to dark. This is first on my list for upgrades. Looking forward to seeing your set up.
Theherofails
Thomas
Phoenix
Im picking up the last few little pieces I need today and will be doing the "re-install" this afternoon. I found a much easier solution for wiring up to the aux switches. Totally forgot about the wire behind the glove box! I want it on the upfitter so I can kill the light when the doors are off, so its not so distracting/eye catching for other drivers. Entire install with parts is under $50.
amccue90
Andrew
Illinois
2021 Badlands
So I was looking to hook up one switch to a dash cam, so I can switch off parking mode while parked in my garage to save the battery. But it turns out the fuses to the switches are not always on, and turn off with the vehicle.
I ended up just wiring to the battery for now with my own fuse and switch, but is there an easy way to rewire the aux switch so that it can stay on with the vehicle off?
ICUGAZN
Kevin
2019 Raptor
Can't wait
GiveItaTri
Robert
WI
F150, Big Bend
Threads like this make me wish I had learned more about power and wiring when I was young. I only got as far as licking 9-volt batteries.
Lucky Nut
Lucky Nut
Memphis, TN
97 TJ
Anyone successfully hooked up a "kill switch"? If so, I'd love to hear the step-by-step.
Advertisement
Advertisement
