Bschurr
NY
I made a few things…
covers for the soft top latches in the cargo area
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 62E1EC8D-1472-4454-8B99-E0475E4B18D4
lug nut hole covers for the spare (debossed bucking Bronco logo for style points)
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 90EAAEC8-122B-4B0F-864E-26808FB6E886
swamp2
swamp2
Bschurr
NY
And this is? I'm it'll be obvious in hindsight...
That is a 3D printed cover for the location in the cargo area on each side where the soft top latches install. I hated the unfinished look without them so I fabbed up a nice solution.
(apologies - I added descriptions to the post)
Johnny Mo
Westchester County, NY
teachu2shoot.com
Ford Fusion Energi, Ducati XDiavel
The only thing that would go nicer there is a RockWerx D-Ring hardtop bolt - you could then use it for a vertical cargo net attachment point. Nicely done!
Grandpa
Pennsylvania
2023 Manual Sasq.
IAG bumper lights and F150LEDs Spartan CREE lights last weekend.
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_2358
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_2359
vrtical
Doug
GSMNP, TN
Fords
Nothing exciting gearing up for Supercell. On my 3rd oil change targeted for 11k a bit early as I am busy the next couple of weeks. I change it every 5k and did a 1k initial. Using a Ronin oil plug makes life easy.
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1710338071414-dh
Bschurr
NY
Thank you! Funny you should say that - this was my setup in my soft top Badlands
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_6142
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_6143
I simply used a picture hanger with an Integrated D-ring and a small Note-Ize mini biner and a recycled net from a former Lexus RX350 that my daughter destroyed.
it all worked great!
swamp2
swamp2
Cool. Great texture match to factory, luck or intent?
swamp2
swamp2
Advanced Wheel Locks:
Black, set of 5. These best pretty well all of the techniques to (often easily) defeat other designs. Check out the comprehensive comparison test here:
Bschurr
NY
swamp2
swamp2
Spare tire dressing plugs. Actually found a UV/weather/chemical resistant size that fits the KMCs. Most standard rubber stoppers are very poor with UV.
I have 2 additional sets of 3 plugs for FREE. DM me.
DillonC
Dillon
Ga
2012 f250, 2019 expedition
Not raptor specific, but I did build it to fit around the spare (and future larger spare).
Built a hitch carrier for my fishing/beach cart. Also doubles as a luggage rack now when it's on there.
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1000002943
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1000002941
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1000002942
604Bronco
British Columbia
www.bronco6g.com
Nice setup/cart. Does the cart bolt to the rack, or how does it stay on there? I assume not just gravity...
DillonC
Dillon
Ga
Thanks
In the pictures it's just sitting, but I'll probably just use two small ratchet straps looped around the carrier and floor of the cart.
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
Started the Dynamat install. Got through the cargo area and driver's side door. Going to break up into several parts as it is a bit time consuming to disassemble/reassemble.
Caught a few photos on the Raptor in the rain here in LA.
