What is this?
stormshadow3800
Jeffrey
Wisconsin
VW Jetta TDI, Bronco Badlands (SAS)
Found in my tool bag zipper pouch. Assume another tooling piece left behind? Appears to be snapped off at the thread end.
Ford Bronco What is this? PXL_20220401_234346859
Ford Bronco What is this? PXL_20220401_234420359
amccue90
Andrew
Illinois
2021 Badlands
for the doors
check your manual or one of the videos posted by bronco nation.
Don't throw it out!
like 4 minutes 20 seconds
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Isn’t that a pin you screw into the hinge to get it aligned or something?
stormshadow3800
stormshadow3800
Jeffrey
Wisconsin
Wow ok, I feel dumb now...... Haven't taken the doors off yet. It looks like shit for something put into a new kit. The end is uneven and looks like it snapped off.
stormshadow3800
stormshadow3800
Jeffrey
Wisconsin
Sure as hell doesn't look finished like this! Does anyone else have one that looks as bad as mine?
Ford Bronco What is this? 1648857673583
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
How brave are you?
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
I had no clue either. And yes, mine looks just like yours.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
It's going to look worse once you start using it to put the doors back on. It's probably Delrin plastic, which is a hard, durable industrial plastic but with a low finished surface quality.
If the alignment pin were made of, say stainless steel, it would eventually start flairing the hinge bolt hole. The alignment pin is made of plastic to prevent damage to the door hinge.
Form follows function. Not everything Ford does is fucked up.
The alignment pin is steel.
M&M Beer
Marty
Ford Edge-F-150 Supercrew
VERRY IMPORTANT PART DON’T THROW OUT! YOU NEED THAT ALINEMENT PART TO INSTALL YOUR DOORS.
Similar threads
