What offset are you running?
Utahjazzman
BJ
Ram 1500
Looks great. Thanks for the response!
  • Like
Reactions: Dez
Utahjazzman
BJ
Ram 1500
Yes and no. Since mine is a big bend they are not stock size but are the stock tires/size for the badlands. 285/70/17 BFG KO2's.
I think the fact that my wheels are 17x8 also helped keep the poke in check. The backspacing of the wheels is 5.21".
You have any other pics from a little further away? I want this exact same look. Thanks!
Dez
Geoff
Framingbury, MA
1967 Mustang, 2021 Hyundai Kona, 2021 Ford Bronco
I don't have any straight on from farther away but hopefully these help.
Ford Bronco What offset are you running? IMG_6437
Ford Bronco What offset are you running? IMG_6430
Ford Bronco What offset are you running? IMG_6422
Ford Bronco What offset are you running? IMG_6411
Ford Bronco What offset are you running? IMG_6412
Ford Bronco What offset are you running? IMG_6402
Ford Bronco What offset are you running? IMG_6401
Ford Bronco What offset are you running? IMG_6386
Utahjazzman
BJ
Ram 1500
Looks great. Thanks
Bybotie
Nigel
Edge ST, 2021 Mustang Mach1 HP, 2021 Bronco
Method Racing 703's with 0 offset.
Ford Bronco What offset are you running? 20220201_153319
Ford Bronco What offset are you running? 20220121_112613
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Method 705s - 18x9 and +18 offset
Toyo ATIIIs - 37x12.50x18
3" Coil-Over Lift
Ford Bronco What offset are you running? IMG_0262
Upper Control Arms have plenty of clearance with the +18 Wheels. NO rub at all.
Ford Bronco What offset are you running? IMG_0264
Just the outer bulge of the tire sticks out of the Sasquatch Flares
Ford Bronco What offset are you running? IMG_0203
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
I’m looking at fuel trophy wheels with +6 offset. Worried they may stick out to far. Bronco I have ordered is a 4 door bigbend will be adding 2 inch lift. Any thoughts??
20x9 Fuel Blitz with 35/12.50x20 Nitto Ridge Grapplers. The Blitz has a +1 offset. Bronco is a Badlands with Sasquatch and Ford Performance Flares and a leveling kit, all installed by the dealership prior to my purchase (originally spec'd out for the initial customer order before they backed out.)
Ford Bronco What offset are you running? 1647383077090
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Old post but wondering if you had to remove the crash bars for this setup? Im looking at wheels and tires with this exact size and offset 17x8 +18 with 285/70/17 KO2's
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Just to add some info for anyone reading this thread:
Offset is no good without the wheel width. ex: 0 offset on 8" wide wheel is .5" different than 0 offset on 9" wide wheel so always important to look at both specs
Dez
Geoff
Framingbury, MA
i did not have to remove cash bars. No rubbing whatsoever.
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Just thinking:
Is poke for those who can’t?
derichio02
Bo
Southern California
Do you have any additional pics? Im interested in the flares. Do they stick out farther than the stock Sasquatch flares? With my 17x8.5 0 offset Im about an inch past the stock Sasquatch flares.
Jeverall
James
Tampa fl
Jeep Grand Cherokee
-18 on 20x10
Ford Bronco What offset are you running? 0961EB0A-9C64-4E1E-9105-772BFA6FEE81
‘21OBX
90Bronco19
2022 bronco outer banks
+18 17x8.5” 4.46” backspacing
Ford Bronco What offset are you running? E7874488-B041-4F07-A4DB-B717ABF83607
Ford Bronco What offset are you running? CC77BB18-8341-40F6-9FD0-BB98818E9D7D
7722 Bronco
Kentucky
2020 Explorer ST/ 2019 F350 CC DRW 4x4
Mickey Thompson Sidebiter II wheels, 0 offset, 9" width, 17" dia., running Mickey Thompson Baja Boss MT's 35x12.50x17 tires, SAS flares.
Ford Bronco What offset are you running? 20220602_231709
Ford Bronco What offset are you running? 20220602_231724
