What part/accessory are you looking for that a company has not made?
BearPatrol
23 Bronco
Also, a soft-top for the 2 door that folds all the way in the back like the stock 4 door soft-top. Not a fan of how the Bestop looks folded back.
ezapar
Seattleish
23 Wildtrak LUX
N9WXU
Joseph
Vail, az
‘55 Willy’s, Liberty, F-150, Transit, ‘22 Bronco
I wanted a chase/reverse light bracket that did not interfere with the brake light or spare tire. The lights that clamp to the camera stinger did not make me happy. So I made this. A real fab-shop should be able to make it lighter/smaller.
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 1 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 2 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 3 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 4 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 5 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 6 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 7 of 8
Ford Bronco What part/accessory are you looking for that a company has not made? Library - 8 of 8
seanoj
Sean
Crown Vic, Porsche 911
4 door soft top roof rack that allows you to open the rear fully, and is robust enough for a rooftop tent (200lbs dynamic, 500lbs static). +light weight +not noisy +priced around $1k +removable in an hour or two. I have found numerous that will check most of the above, but not all. The DV8 comes close, but can't pop the rear up and I have heard things about NVH at speed.
Beadlock rings for the Sasquatch tires. Not trim rings, but real beadlock. Ford Performance is just silly $$$.
ricstang
Richard
Lincoln, NE
1995 Ford Bronco
A panel to protect the inside of the tailgate. It is a nicely body colored surface that is just asking to be scratched and dented by anything lose in the cargo area.
MayhemMike
Mercury
I love your stuff and I have the roof rack for the 2 door. What I would love is if you were able to redesign the front bracket so that I could take the roof panels off without taking off the rack. I believe there is enough space between the panel and the rack but the bracket in front is to close to be able to remove the panel.
Ford Bronco What part/accessory are you looking for that a company has not made? IMG_0170
I have to ask, what is the sprayer used for? I surf fish as well and can’t figure out what the sprayer is being utilized for. Thanks.
Tricky Mike
21 Bronco
Whatever you make, drop your prices ("bronco tax") so things are affordable. Undercut your competition and be the change that needs to happen. Be the leader.
Please
That's going to take an established Bronco vendor like Tom's, Duff, Wild Horses, etc to jump fully into 6Gs.
edgarmcgauley
Edgar
Fort Worth, Texas
2022 Ford Bronco 4-Door Soft-Top
Repair/reinforcement kit for soft-top that does not use plastic pieces destined to fail.
edgarmcgauley
Edgar
Fort Worth, Texas
Also, interior cargo area mount for spare wheel assembly for those who deleted it off the tailgate.
sage729
Ian
Maryland
4dr Big Bend soft top, Area 51, non SAS, mid pack
Stiff lockable tonneau cover for 4dr cargo area when the top is off. Needs to also keep the back seats from being lowered.
Area51BS
Ron
Badlands non SAS 4dr 2.3
If it’s in Florida, then it is bug spray for no-see-ums. Or just h20 to rinse feet/hands.
