Which Method wheels do you like?
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
How do they ride? I was between them, Toyos, and Ko2 but eventually chose the Ko2. Regretting it now tbh.
I like them so far. The stock K02s were bad in the rain from my initial impressions. The rear wheels would easily break loose if I gave it aggressive throttle when doing a turn from a standstill for example. But with these I haven't seen that yet. I'm in South Florida and it rains here constantly so I wanted something that was good in the rain.
I just aired them down to 35 but haven't had to test how they ride. I was driving around with them at 39 since that's how they came from tirerack. The ride was just fine but they did seem to have slightly more road noise but not sure if that was just because they had too much air.
I'll update you once I test it out at 35psi.
HenryGX
Henry
Non Sasquatch Badlands (Not lift)
Method 706 17x8.5-0
Falken Wildpeak AT3W 315/70/17
Looks totally sharp! My friend is considering that 706 or 312 matte black method wheels and nittos for his Bronco.
Copper Red NC
Andrew
08 Miata/2022 Bronco
Not my bronco but my aunt’s… however I did spec out this setup for her haha. Not a Sasquatch but is a Badlands so it still has Bilstein’s just like half an inch lower or whatever the small difference is.
17x9 -12 Method 315’s in a machined finish
315/70/17 BFG K02’s (and they’re C rated!)
1.5 inch collar front level
Ford Bronco Which Method wheels do you like? IMG_3068
Ford Bronco Which Method wheels do you like? IMG_3072
Ford Bronco Which Method wheels do you like? IMG_3070
Ford Bronco Which Method wheels do you like? IMG_3074
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
Out Bronco has the Method 706 in Bronze with 0 offset and 4.75" backspace. It is a perfect fit with the @ADV Fiberglass and RPG Mid Travel Kit. We are running the Falken Wildpeak RTs in a 37x12.5r17.
Ford Bronco Which Method wheels do you like? DSC05952
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Love ours Method 703s with Bead grip on Nitto 38" Ridge Grapplers!
Ford Bronco Which Method wheels do you like? sep 23 4
Ford Bronco Which Method wheels do you like? sep 23 5
Ford Bronco Which Method wheels do you like? Sep 23
Sloth
SWFL
2022 Bronco
Method 706…
Ford Bronco Which Method wheels do you like? IMG_6463
