Who's adding Keyless Keypad Entry and why?
R u adding keyless entry keypad
  • Total voters
    702
CeeCeeBronco
CeeCee
Houston
When I go kayaking, biking, hiking, etc. I usually don't want to carry my keys in my pockets or risk losing them in the river. Also when I'm on vacation or traveling for work hundreds of miles away from my extra set of keys I don't have to worry about that one time I'll be an idiot and lock my keys in the car. It's a feature I've found myself wishing I had on my Tacoma several times so figured I'd better add it!
I don't think it's possible to lock your keys in a Bronco (absent a key pad, I guess). Am I wrong on that?
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
Yep. It will honk at you if you try it.
Cetacean Sensation
PNW
Bronco & Bimmer
Had it on my 99 Explorer and the keypad got used all the time when getting things from the car or locking the keys in while at the beach or in a kayak.
For 100ish bucks it's an easy choice for me.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
You can lock them inside using FordPass and a faraday pouch.
Cetacean Sensation
PNW
Bronco & Bimmer
What if I also want to lock my phone in at the same time? Or if I'm parked in a place without cell reception? Need the keypad.
For people who want the keypad, it's an irreplaceable feature.
BroncoSarge
Jeffrey
Perhaps you misread. I lock my phone, key and valuables inside my cargo area enclosure at the beach using the keypad. I put the key in a faraday pouch so it doesn’t work. Found that with the doors off, the truck will still start sometimes. I have mine in the fuel door and use it a lot. Especially if I am out in the yard and need to get in. Don’t have to get my key or phone. It is irreplaceable for me.
Ford Bronco Who's adding Keyless Keypad Entry and why? B70EFF74-AB3F-4748-882C-ACBBC3A26A79
Ford Bronco Who's adding Keyless Keypad Entry and why? 4F90186B-5072-4065-B196-3D75AA32FBAC
Apple Blossom
Nancy
Ontario, Canada
2018 Ford Edge
I have had a keypad since 2003 and they are the most useful part of a car/truck/Bronco. After tires, engine etc. It was the first option I put on my Bronco when I ordered it.
Bronccraig
Craig
Orlando Florida
2009 Challenger RT Hemi Orange
Me click add keyless entry…FORD…thats gonna delay your build 1 year…me unclick…
I3lackRose
Justin
Ohio
I wish it came not installed with the 3M ready to place in your desired location. Seen the gas tank cover placement and I like that. Apparently these are throw away tho which I don't care for. Why you would not make these replaceable batteries is beyond me in today's world of plastic and e-waste concern. Bet I crack it open and still try to replace the battery myself. 🤫
Gfsteam
Northeast
Ford Edge
I’m adding to my fuel door as well. Does anyone know how to program through Forscan? Would rather program myself if possible these units have to be programmed the old method of switching key multiple times does not work.
I3lackRose
Justin
Ohio
So key in the faraday pouch your bronco still starts occasionally? Sounds too risky.
TNBronc4344
JT
Kingsport
Yeah i love the feature and have had it on most of my Fords. That said when I finally placed my order it was accidentally left off. Can this be added as an accessory after the fact ?
MnLakeBum
MN and FL
‘18 Range Rover Diesel
It can be ordered after the fact. I have it because I don’t want my keys with me when camping, skiing, diving, cycling, etc. The area where we sometimes camp 200 miles north of our home along the Canadian border have zero cell coverage so using the Fordpass app is not an option.
It took me just a few minutes to remove it, apply new double side tape, and mount it under the gas cap.
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '24 GR Corolla, '94 VFR, '04 SV
You can install it after the fact, because that's exactly how Ford does it. In fact, it's preferable to do it yourself, and put it where you want it (not add a lump on your door). There still seems to be a perception that this is properly integrated in the vehicle design, using vehicle battery power, like past Ford vehicles. It is not. It's just a stick-on remote, essentially, whose battery will die at some point.
