Who's Got The Best Way To Open Tailgate From Inside?
Tina
Tina
San Diego, CA
2022 Ford Bronco 2-Door
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Keldel
Kellie
Indiana
Ford Bronco
So who here has figured out the best way to open the tailgate from inside the truck? Say when sleeping or camping in it. Isn't there an emergency release inside the plastic cover? Has anyone modded one with a handle? What is everyone doing for this? Thanks in advance.
Just thinking of this! Going to Colorado sleeping in the back. Would like an out if a critter blocks the way out from the front!
Roll Sound
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
Anyone have any fresh ideas?
Headsong
That's pretty elaborate...and obvious for anyone peeking in. I'll likely open that up and attach some sort of cord/cable and try to not be obvious...still can't believe that it's even legal to not have easy access? I mean they have to have them in trunks, right? Why not here?
Meraki Hammocks
Randall
2021 4dr 2.3l 7 speed Big Bend Cactus Gray Bronco
I just found this thread. I looked at the latch over the weekend. I did figure out how it operates. When I have time, I am going to mock up a replacement for the plastic panel before making and permanent mods to that panel.
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
Did you ever find out how to get out or have you been stuck inside your Bronco this entire time??
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
Well,..... in a trunk you may actually be really stuck. In a Bronco you are not stuck. It would be very similar to sitting in the back seat of a two door unit. You shove the passenger seat forward, open the door and get out.
Gtrekker
Gary
NJ
If you have a MIC top.... simply tap on the window 3 times, if someone doesn't respond. Keeping knocking.... someone will show up.
In s soft top.... just yell till help arrives.
Slow day.🤔🛫
