Wildtrak bumper selection
BroncoKong Jr.
Andrew
If you go to model highlights of Black Diamond it tells you in the description Powder coated steel bumper (picture of capable bumper) and as you read on it says its available on all series but you can't choose it on Wildtrak
They screwed up, natch. Go by the order guide. Capable bumper isn't an option on any trim, but it's standard on BL and BD.
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Only stuck until you replace it. :)
Your right you can probably find a nice alternative some day. But the point is why should anyone have to? You just spent 30 to 60K for the vehicle and now the bumper needs to be replaced because it is inferior. Ford should give you more options within models. I feel their front modular bumper is very nice.
Again, why did they drop the ball on the rear?
Half-baked...
da_jokker
Jeep Wrangler JKUR
I checked the B&P today. The $575 difference is only for Black Diamond and Badlands builds. These builds come with the "capable" steel bumper and bash plates.
The Wildtrak does not come standard with the steel bash plates or a steel front bumper (modular or capable). When you upgrade to the modular bumper, you get front bash plates.
It looks like the $250 difference is the front bash plates. I went for the full bash plates on my Wildtrak build. Even though I don't do a crazy amount of off-roading, it will protect the undercarriage from the occasional 2x4 dropped in the highway :)
But if you go with the bash plates, you can't get the roof rack.
Mpali
Mpali
Illinois
2022 Wildtrak
If you look at the new image of Wildtrak on Fords build site it looks just like the capable bumper, is it?
Mikedanalexa1
Coinholder1982!
Plastic and the only upgrade option available is Modular bumper. Capable is not an option on 22 Wildtrak. Might be an option from parts dept after the fact, but not sure on that.
I just received my build date 9/26/22. I ordered the wildtrac with high package, the build picture shows capable bumper, I was told by dealer high package and above gets capable bumper. So I did a build on fords website, and when you switch from mid to high, or luxury the bumper changes .let’s see what happens when it comes in. Looking at fab fours vengeance and dv8 modular
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
I'll be selling my capable bumper from my Badlands if/whenever I get the Bronco.
Broncotrax
NORCO
Which afterm you looking at?
I like the Warn Elite with the winch so I can set it up like my JK but I need the bumper to come with optional mounts to accommodate for 1.5" body lift. (raise the body - raise the bumper)I'll be running 37's but I will stick with factory Badsquatch suspension but upgrade tie rod ends. I see many failures now that people have modified suspension to get the 37's to fit. Factory geometry will be more successful. Body lift is a fraction of the cost anyways. Also raising the bumper will help restore approach angle loss with the winch bumper.
2fast4u
Rancho Cucamonga CA.
Shelby GT500 and Bronco Wildtrak
On 2023 orders. If you upgrade to the Modular bumper do you still get stuck with the cheap looking plastic rear bumper?
