Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)?
Hyfly
Idaho
BRONCO
Got my build date for 02-07 for a non squatch Black Diamond. Looking to get some tires ordered since it seems like a lot are at least 1-2 months out.
Wanting to keep the stock steelies and throw on a 1" leveling kit.
Hoping to get the BFG KO2 315/70/17
Anyone know how/if these will fit with the stock wheel offset and a front 1" level only? I am okay removing the crash bars if needed. Just not sure if the stock offset will work. I am a newbie when it comes to wheels and offsets etc.
Thanks for any input you might have!
Collinabc123
Collin
Hummer h3
Those tires might be too wide for the stock wheels
Hyfly
Hyfly
Idaho
BRONCO
The min rim width recommended is 8" and the stocks are 7.5" so I think it is a little too wide. But I have seen. lots of people putting wider tires on 7.5" rims also where the recommendation is at least 8.5" so I thought it could be done?
Thank you for that feedback!
JohnForyt
Columbus, OH
Plenty of folks on here say things are doable that aren’t recommended from a safety or practicality perspective.
Hyfly
Hyfly
Idaho
BRONCO
That is a good point. I guess that is the point of this thread. Just trying to figure out if it Is doable and okay or not.
If not I have an alternative that is a little smaller. Just want to go as big as I can on the stock option.
PWillette
Parrie
Maine
By all accounts I have seen the steelies do not have the correct offset for 315/70-17s and will rub, several threads out there
Hyfly
Hyfly
Idaho
BRONCO
Thanks,
Looks like 285/75/17 is going to be my best option!
PWillette
Parrie
Maine
atlbrvefn
Black Diamond Bronco
I have some Toyo 35x11.5 going on my steelies tomorrow. I’ll report back with pictures.
Biltwild
New York
2014 Nissan Titan Pro-4x , 2021 Ford Bronco 4Dr BD
I have been running 315/70r17 tires on a set on 17” method hole wheels with a 0 offset. No lift. Crash bars removed. No rub at all lock to lock. Changed out fender flares to Sasquatch flare to lessen the poke.
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? ACFDC768-F5F6-4522-8B23-99C9F811E2AB
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? FE6C9E8F-3C2D-4D82-80F0-44AEF1E3BADE
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? AE6ED821-7EE5-46A2-ABDF-1029B36CDABE
Hyfly
Hyfly
Idaho
BRONCO
You have any lift or level?
Biltwild
New York
No lift or level. I bought the 2” lift from zone off-road, but have not put it on yet. I kinda like the look without the lift. Drives great and feel more stable with wider wheels.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Stock steelies on Nitto Trail Grapplers 315/70/17 with 2” 4WP level kit..only issue i came across was i had to remove the tailgate bump stops for the spare. Due to offset, there was no clearance for the bump stops. No rattle or anything, i actually like it closer to the gate.
Hyfly
Hyfly
Idaho
BRONCO
Yea I love the look. Great job.
